Fm tuner section is no good. You replace- repair not cost effective. This outfit has very good units and tremendous customer service. Crutchfield Car Stereo Speakers Home Theater Pro Audio 4k TV
SOURCE: better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is
really bad (such as in a valley) the antenna would just amplify the
noise as well. Look for web based radio in this case or if you have
cable there are stations on it.
Jeff
SOURCE: I have a JBL MR-17
3possible problem, there could be a bad reception, a loose antenna, or there was a problem on the internal resistor for antenna signals
SOURCE: 2002 monte carlo ss am/fm
I would suggest that the antenna is bad. If the detailer sent the car threw a car wash or just by coincidence the connection may have failed at the base of the antenna. Cheapest troubleshooting solution is buy a replacement antenna for the car and just connect it to the radio without installing it. If the reception dosen't get any better then replace the radio and return the antenna. To recieve AM you must ground the outside body/base of the antenna (not the whip part) to a bare metal part of the car (door jamb etc.). Most car antennas have a TINY center conductor somewhat like copper leaf in the antenna cable that increases the possibility of failure.
SOURCE: cobra cb radio, model 75
You didn't actually have a "category" for CB radio so I picked the closest thing to it but in no way does it resemble a speaker and sub woofer problem. I did not continue with the query because the CB is in an RV and not colocated with the computer and I decided there was no way for you to diagnose the problem without me knowing more about the system installation. I need to get the RV in to someone who knows CB radios.
