Question about LG WM-2277HW Front Load Washer
Fowl odor in front loader - LG WM-2277HW Front Load Washer
    Problem Solver:
  • 8 Answers
The drain line from the washer, has a filter screen that needs to be cleaned, more than likely. Remove the hose, clean anything clogged at the filter basket screen, replace the filter screen and hose, and the odor should go away.
Posted on Mar 28, 2011
  • 1,543 Answers
Clean out the small holes in the gray door gasket (at the bottom) to allow water to drain back into tub. Open access door at bottom left on front of machine, use small hose to drain remaining water from machine, remove and clean out filter there. Re-install. Run washer on the tub clean cycle if you have that cycle, or if not, use the longest, hottest cycle you can, but make sure to use a commercial washer cleaner like Affresh, Washer Magic, Whirlaway hot tub cleaner, etc., with no clothes in the washer. After cleaning tub, make sure you only use one tablespoon of HE detergent per cycle, and only one teaspoon of fabric softener per cycle if you use softener.
Posted on Feb 13, 2011
SOURCE:
Water remains in hose and smells
Front loaders are known for bad odors. Run an empty cycle with double bleach and let the machine totally dry out, with the door OPEN. The bleach will kill the mold spores and letting it dry out will prevent more from forming.
Dec 19, 2012 | GE Wh12x10309 Heater for Adora Front Load...
Fowl Smell
If the smell is a mildew type odor this is common with the newer energy efficient machines. To remove the odor I would suggest using a product called Affresh or Smelly washer. These used on a monthly basis will help eliminate and keep it from coming back. If it is practical to leave the lid open when not in use that will also help. The products I talked about are available at Target, Lowes and grocery stores near the laundry detergent.
Apr 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
It had a bad odor
Check whether the odor generated from your drain system external to the m/c.
ie- your discharge hose end connection
Apr 07, 2010 | Frigidaire ATF6000ES Front Load Washer
I have the whirpool duet sport washer & dryer and everything I wash in the washer smells bad. The washer always smells not even washing with the pure bleach cycle works
Odors related to front loader washers is a common problem. The following link gives some pointers on things you may try to minimize odors and to keep them reoccurring:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Many of these tips are mentioned in the owner's manual of these washers. The most important factors inlcude:
1. Leaving the door open when not in use.
2. Checking for small garments that end up in the door bellow area.
3. Using HE detergent only.
4. Checking the drain pump reservoir for debris.
These simple factors will not only minimize odors, but will keep them from coming back. I personally own one of these front loaders and have never had an odor problem in the 9 years I've owned it by following this regiment.
If you have your doubts or have questions, please post back and let me know. I do hope you find this information helpful.
Mar 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer has an odor like mildewing clothes, but I can't find any.
all front loaders are good for that, none of the manufactures have really found a solution to clothes stinking like that
Jun 23, 2009 | Whirlpool GHW9200L Front Load Washer
Fowl odor (sewer like) when washer is running.
Can you see the washer drain line,or is it inside the wall.
You should never smell sewer, I would find a good plumber,or a handy man that knows plumbing, and have him open the wall (if needed)
and install p-trap where the washer is located, at about floor level.
From what you said I think that someone ran a straight line to the cellar and installed the p-trap down there, also have them check the line to see if the line has been connected to a breather line, if not have him install a breather line right there with a one way breather valve inside the wall. The buildup and mildew around the compartment is due to the way it was made by the MFG of the machine, most 1000.00 front washers have a very poor design with this. All you can do is to remove it and clean it with bleach once a month. If you live in an nice area,but not very rich, the cost to do the drain should be around or under 350.00. I hope you get this squared away with no problems.
Mar 21, 2009 | Kenmore Washing Machines
Odor from the inside of our front load laundry washer
leave the door ajar between uses if possible , there is a product on the market now to assist the odors of front loaders. www.affersh.com . you MUST also use an HE detergent ( specifically designed for front loading washers)
Nov 13, 2008 | Kenmore Washing Machines
Washing machine odor
www.affresh.com this product has been devoeloped to lessen front loader odors. you NEED to be using an HE detergent. low sudsing ans specifically design for use with front loading washers.
Oct 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WM-2277HW Front Load Washer Logo
409 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
