Question about Panasonic PV-V4522 VHS VCR
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel 3. How can I get the VCR to record multiple shows on different channels with the cable box?
    Scholar:
    New Friend:
  • 71 Answers
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Posted on Nov 21, 2011
SOURCE:
Timer mode is locked on vcr
You must have set a timer record. Press the button that sets a timer recording and cancel them. If you have the manual check what it says if you don't have a manual Panasonic do have PDF of most videos free. IF you can't clear try the factory reset opition.
Jan 14, 2013 | Panasonic 4-Head VCR PV-V4525S
Need code for panasonic vcr pv v4525s
Hello
Setup codes for Panasonic VCR with URC4220 universal remote control are:
0035, 0162, 0616, 1062
OK.
Feb 22, 2011 | One For All URC4220 Remote Control
Remote Code for Comcast DVR
See http://www.comcast.com/corporate/customers/customer_support/remotes.html
You will most likely have to use a VCR code and program it to the AUX button.
Feb 26, 2010 | Panasonic PV-C2541 25 in. TV/VCR Combo
I have a Panasonic VCR PV-V4202-A. I want to
You need to go into the menu and look for timer recording,then set in the channel,dateand time the program starts,then press the timer button.It will not start recording until it gets to the time the program starts.
Sep 11, 2009 | Panasonic PV-V4022 VHS VCR
VCR doesn't record since Comcast installed digital box
Try this..Run cable line into VCR in, cable from VCR out to box, then cable from box to TV..this might work...I have done this for YEARS and it is never failed. You can then watch and record 2 things at once.
Feb 12, 2009 | Proscan PSVR72 VHS VCR
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Panasonic code for PV-V4530S
have a panasonic vcr model # pv-v4022-A and need code to add on my cable remote
Sep 04, 2007 | Panasonic PV-V4530 VCR
PANASONIC PV4022
One way is to manually select the missing channel with the numeric keypad, then push "add." There is also an auto program function puts the VCR into a search mode, adding all channels where a good signal is found. Early VCRs (like late '80s or so) did not have this auto mode, but many later ones did. Also, make sure your VCR is set to the "cable" or "CATV" mode not "off-air" Do you have the VCR manual? If not, recheck your model and see if Panasonic has it online at http://service.us.panasonic.com/OperMan/Default. aspx I looked at at a manual for a PV-4651, and it showed functions which sounded similiar to what you need. Check pg. 10-12
Aug 12, 2007 | Panasonic PV-V4022 VHS VCR
How do I Record?
well, seems like your vcr is attached to your tv by the antenna cable which you need to program to get it to record. but he is an easy way to record and you will get a perfect sound and picture. Well, you need an RCA cables. you either have rca cables or scart plug. either on will do the job. you need to take the audio and picture cable OUT source of your channels IN to the vcr. now, OUT of the vcr IN to your tv. on the vcr you should change the channel to either AV or LINE..then you will get sound and picture. let me know how it goes
Jan 15, 2007 | Panasonic PV-8451 VCR
Auto channel programming
The desgin of this unit is such that only the channel being recorded can be viewed. Try to manualy program channel 3 - p.25 in the user guide.. Good luck.
Jan 14, 2006 | Panasonic PV-M2048 20 in. Combo
Panasonic PV-V4522 VHS VCR Logo
242 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
