Question about Yamaha RX-V3800 Receiver
Hi receiver is having intermittent problems with power up & off. at the moment it would only turn on once in 5 times i try to turn on. At one stage it would turn off but then back on again within five minutes by itself & this occurred until i unplugged unit from wall. unit is 3 months out of warranty, Please advise, David
    New Friend:
I got Yamaha RX-V3800 with intermittent power.
Cause by capacitor C4 22nF 630V on the control power board.
After replacing the capacitor, receiver again working OK!
Posted on Mar 24, 2013
  • Mark Gordon
    Mark Gordon Jan 08, 2014
    Is there a diagram that details where this capacitor is located?
SOURCE:
techman
  • 3130 Answers
SOURCE: Double clicking sound- no power
The relay contacts are most likely bad in the relay and will most likely happen again. If you know how to solder, take out the relay and look up the numbers on the internet and see what you can find. If not, try to find where the manufactuer is located and call them to see where you can get a new relay. Good Luck
Posted on Mar 28, 2007
  • 395 Answers
SOURCE: Will only power-on after multiple atempts.
That problem is well known problem with a memory capacitor on the stand up board that is the control board. It is .47F 5.5 volt capacitor that resembles a button battery. The cap leaks all over this board the fluid is conductive and corrosive. So the cap must be removed and the board scrubed clean with contact cleaned and dried before replacing with new cap. the unit can run without this cap but if the power should be removed all customer settings will revert to the default. also check the copper ground screws for tieghtness.
Posted on Jul 08, 2007
ButtFuzz
  • 463 Answers
SOURCE: Yamaha RX-V650 receiver won't power on.
You've probably already tried this, but...
Disconnect power from the mains, remove lid.
Reseat all the low-power connectors in the unit.
Check the thermister on/near the main transformer.
Check capacitors on or near power supply for obvious anomalies (fattness, leaking, smoked, etc.)
Replace lid and, plug back in, do a rain dance and hope.
Posted on Mar 04, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX V2400 keeps shutting off
When it shuts off, does it display anything on the front like "ck speakers" you could have a shorted wire or bad speaker. Sounds more likely than a bad receiver. Yamaha is pretty bulletproof in "self preservation" circuitry! about the only thing that takes them out is lightning and major power surges. I have been selling and installing Yamaha receivers since 1995 and have only ever seen one with a problem that was unrelated to power. and I've done hundreds. If your not using HDMI, and the Video portion of the receiver, I would definately keep the unit $ 1500.00 is no cheap receiver. Try disconnecting the speakers, then turn on the unit with a source connected like cable/sat/fios on then crank the vol and let it set, if it cuts out, yes you've got a problem internally, however, I would stronly suggest metering all of the speakers and wires for shorts. There is an internal fuse as well right near the power cord, you have to pop the top to get to it, If you have a multimeter check the fuse with resistance tone. If you get tone, you have a good fuse if not If you need to replace it. They can be found at Radio Shack etc. If the fuse is OK, chances are you've got bad transistor(s) and needs to go to service. Repair should be under 200, well worth it. If you have further questions, post a comment and I will get back to you ASAP. Hope this helps
Posted on Jun 06, 2009
SOURCE: Yamaha Receiver (rxv3000) has intermitent power problem
Most, but not all of the voltage regulators are cooled by the same heat sink
that the output transistors are attached to and get overheated when you crank up the volume. Although this unit has a cooling fan, after some time the heat sink gets HOT and will age these parts. There are also a group of three current limit/ voltage drop resistors supplying one regulator that will give up too. This is not for most DIY folks. Repairs are available in certain parts of the country. I know of one you can ship the unit to and get it fixed like I did.
Posted on Sep 17, 2009
Power supply problem
Could be a blown amp channel. Once the output transistors go, it doesn't matter if you disconnect the speakers or not, the damage is done. Could also be a voltage regulator, but not as likely.
Apr 30, 2013 | Denon AVR-1911 A/V Receiver - 3D - 90 W...
Intermittent power on problem in desktop
If a desk top unit and you have to try to turn it on several times to get it going I would suspect bad filter caps in the power supply---once on they will function--usually happens in units at least a few years old.
The power supply if removable can be tested or at least inspected for this as caps will be easy to see if bad----
Nov 03, 2012 | Computers & Internet
Receiver will not turn on and is making a clicking sound TX-NR 609
This is the same problem i've had with my POS nr609. I will never buy Onkyo again.. Everyone warned me about the poor quality.. This thing worked for a year and a half, blew the amp., replaced and now another year and a half, f'd again. Save your time, buy a Denon or a Harmon Kardon. Better quality, same features.. Boat anchor here
May 15, 2012 | Onkyo TX-NR609
Intermittant issue for a while now...power on with remote or button on front panel, it will light for just a moment (very few seconds) and then shut off. At the moment, it's in the mode of NOT...
Death throes will become permanent the more it is stressed.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jul 14, 2011 | Yamaha RX-V2090 Receiver
I have a 99 Cabrio with an intermittent start
probably a starter motor on the way out. not an uncommon repair.
Dec 30, 2009 | 1992 Volkswagen Passat
Electrical problems
It sounds like you have a loose ground wire somewhere. If you can't find it, tonight, when it's dark, have somebody turn all this stuff that's giving you problems, on and off, while you watch for sparks.
May 21, 2009 | 2003 Pontiac Grand Prix
Onkyo receiver with no sound
There should be 3 clicking sounds coming from the amp. You amp miss the last clicking sound coming from the speakers ,spk, output terminals. There should be 3 relays on the spk output board. Their 12 contact points may have a layer of black colour oxide. Remove the oxide can fix the problem, perhaps.
1. Unplug the amp.
2. Open the cover
3. At the spk terminal, there is a horizontal board.
4. Look for the 3 relays and take them out.
5. Open the relays and remove the oxide layer by a sandpaper.
6. You need an iron solder, a desoldering pump and solder.
7. If does not help, check for the 24V for the 5 relays. 2 is for B+ and B-.
Sep 08, 2017 | Onkyo TX-SR501 Receiver
Denon 4308
ok sounds simple you ran the lines threw the tv instead all lines should be ran threw the sterio
see once you turn tv off this cuts the outputs out so now no sound will happen
your sterio should be equipted to take inputs of tv
you want everything to be inputed threw receiver thats why they call it a receiver the outputs on tv goto inputs on receiver
you need to redo your wireing so that this which i described is correct again
Jun 01, 2008 | Denon AVR-4308CI Receiver
Sound turns on and off intermittantly through unit
You may have a bad protection relay or solder joint at the relay mount position. This relay prevents power supply "thumps" when the unit is first turned on, and also shuts the amp down when there is an overload problem....accordianman
May 29, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V3800 Receiver Logo
410 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
