Kingston Secure Digital MicroSD / Transflash Memory Card with SD Adapter - 1GB for NOKIA 3110 Classic, 3250, 5200, 5300, 5310 XpressMusic, 5500 Sport, 5610 XpressMusic, 5700, 6085, 6086, 6110 Navigator, 6120 Classic, 6125, 6126, 6131, 613... Logo
ankit jha Posted on Feb 13, 2011
I formatted my phone which is nokia 2700c.and after that my 1gb memory card is asking to enter password which i had lost.......so plz help me to unlock the memory card.....
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
270
Points
Nokia 3110 memory card password sent me this id
[email protected]
62helpful
5answers
I have nokia 2700, i forget my memory card password. & i want to recover my deleted files from memory card , so bcoz of password my memory card is locked i want to unlock it
Hello Kharat,
To unlock the Nokia 2700 Classic memory card password.
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FExplorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file to unlock
Also visit :
http://www.mobiclue.com/recover-memory-card-password-from.html
My nokia 2700 classic mobile maemory card is locked during reset my mobile . when my mobile memory card ask me plz enter password . plz tell me solution
hi friend, if you not entered any password into your memory card. then, connect your mobile with computer & select an option mass storage at connecting time. then, formate you memory card. then, disconnect your mobile from system. and again do formating by phone in file manger. your problem is fix.
Regards Rakesh
3helpful
How to remove microsd memorycard password
The way is open your memory card from your phone and insert another phone which also support micro sd memory card. when you insert that then you will see memory card lock unlock memory card. first cancel that and Enter the tools option and go to memory card option. try to format memory card. if format memory card then from your memory remove password. thanks
2helpful
1 GB micro sd memory card for my mobile nokia 3110c ..
try reformatting your memory card, however, previous data will be lost...
To format a memory card, select Menu > Gallery or Applications, the memory card folder , and Options > Format mem.
card > Yes.
When formatting is complete, enter a name for the memory card.
2answers
How can format the phone memmory of NOKIA 3230
Download user guide from:
http://nds1.nokia.com/phones/files/guides/Nokia_3230_UG_en.pdf
Page 163
Formatting the memory card
When a memory card is formatted, all data on the card are permanently lost.
Some memory cards are supplied pre-formatted and others require formatting.
Consult your retailer to find out if you must format the memory card before you
can use it.
• Select Options→ Format mem. card.
Select Yes to confirm. When formatting is complete, enter a name for the
memory card (max. 11 letters or numbers).
Backing up and restoring information
To back up information from your phone’s memory to the memory card, select
Options→ Backup phone mem.
To restore information from the memory card to the phone’s memory, select
Options→ Restore from card.
You can only back up the phone memory and restore it to the same phone.
Locking the memory card
To set a password to lock your memory card to help prevent unauthorised use,
select Options→ Set password.
You are asked to enter and confirm your password. The password can be up to
eight characters long.
Your rating would be most appreciated.
Feb 20, 2009 • Nokia 3230
2answers
Unlock 1 GB micro sd memory card of Kingston Made
there is no solution except to format the memory card. and that would mean losing all the data. i'm sorry but that is the only way.
61helpful
9answers
Password forgotten nokia n73 memory card
After restore setting know My Nokia N73 Memory card is on Password and I am not forget my Memory card password help me
9helpful
3answers
hi this is Aravind , i'm having 1 GB micro sd memory card for my mobile nokia 6233 ..... and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in other phone the memory card is not openinng its asking for password .... i have tried also by connecting the data cable but in nokia pc suite its showing that there is no memory card ...., i had also tried thru card reader's but its not opening ./... is there any solution to unlock this card without losing the data in memory card ... plz help me out ........
i have microsd card 1gb card of kingston. it is locked & i want to unlock my memory card without losing my data. so pls send me tips for unlock the meemory card
i forgot my password...pls help me unlocked it without losing my files n data... i forgot the password of my micro sd memory card 1 gb , i don't bother about data, how to open , pl explain.
26helpful
7answers
my memory card is locked .i use a nokia 3110c model. please give me the solution
19helpful
6answers
code to unlock the micro memory card 1GB of nokia 6300
Top Kingston Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Kingston Cell Phone Expert? Answer questions, earn points and help others
