Question about Sanyo DP42848 LCD TV
Tv shows power but no signal at all. power indicator light flashes about every 30 seconds
    Master:
  • 324 Answers
The flashing light indicates a power supply problem. If the set is under warranty, exchange it.
If your warranty is expired, take the set to a good TV repair shop and ask for an estimate.
Posted on Feb 13, 2011
SOURCE:
I moved roku from one tv to the other I see the light on but different inputs still show no signal
Make sure the Roku is on the same input that is selected. With that setup properly, unplug the Roku power for 30 seconds and then plug it in, then it should go through it's setup sequence.
Dec 28, 2014 | Roku Televison & Video
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Tv will not turn on when tried on either tv or with remote green light flashes 3or 4 times then turns into red flashing light no picture or sound at all.Have tried changing batteries in the remote and fuse...
Hi.The signal lights red means the primary power of your tv is good and the signal lights green indicate the second power.If the green lights is flashing it means that they have shorted parts in the crt board.Maybe the problem is in the power section of the crt.Need for troubleshoot or repair the crt board.
Jul 03, 2011 | Panasonic Televison & Video
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
16" lcd new out of box flashing blue light on power indicator
Under a year old tv?This tv have power supply problems.Call the for warrenty repair.Or tries websites like shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 14, 2010 | LG 32LG30 32 in. LCD HDTV
My tv turns off after I turn it on.
This is most likely because the TV is going into "Power Save" mode. It is not detecting any signal on the input it is set for. When you first power it on, make sure there is a signal to the input that you have selected. This normally takes about 30 seconds, but if the TV is set for the VGA input it can happen quite quickly.
Apr 09, 2009 | JVC AV-65WP94 65" Rear Projection...
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
SONY TRINITRON KV-28LS35U
Error 11 means the 8V supply is missing.
Check the power supply.
Jul 25, 2017 | Sony FD Trinitron WEGA KV-30HS510 30" TV
Sanyo DP42848 LCD TV Logo
147 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
