SOURCE: iPod Won't Charge
I am assuming that this is the First Gen iPod Touch.
My friend had this problem and the way that I fixed it for him is to drain the battery completely, so that it won't turn on. (Even the display shouldn't turn on and say VERY LOW BATTERY with a charge icon).
Plug it into the WALL SOCKET and charge it for 24-48 hours.
If this doesn't work, then the battery is defect. If it is still in Warrenty.
Visit the Genius Bar in any apple store and see what they can do
SOURCE: My iPod Touch is plugged in but isn't charging.
call 1800-apple and the will hook it to the cumputer and they will help you
SOURCE: iPod Touch got wet and the battery won't charge
Sorry, that will not help. When I look at water damaged iPod, 99% of the time something inside has been shorted out and has to be replaced to fix it (that is if the other parts are still working okay). From what you are describing about it not having power on its own, it sounds like the logic board inside was fried. This part can be replaced, but it would be about the same price to fix as it would be to buy a new 8GB 2nd Gen.
SOURCE: "Charging not supported by this accessory"
The iPod 2nd Gen changed how it charges and all those devices that once charged your older iPod, will no longer charge this one unless you get the adapter which is at the apple store and I have seen it at walmart for about $30. that device converts the power for you so it will charge. my adapter works perfectly.
SOURCE: My Ipod touch won't turn on
Try restoring it...here's how...
Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
