HP Pavilion dv7-1132nr Notebook PC Logo
A
Anonymous Posted on Feb 13, 2011
How do i find where my audio files are stored
Anonymous
Level 3:
Genius:
  • Master 1,542 Answers
  • Posted on Feb 13, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1542
Questions
5
Helped
287209
Points
4659
Hi
they are normally stored in documents music
hope you can find them
1helpful
2answers
USB containing MP3's is inserted but deck says "unsupported" and will not display songs. I transferred songs on an IMac to the USB if that matters.
Using an unsupported USB device can result in abnormal playback or display of the audio file. Even if you use the USB device conforming to the above specs, audio files cannot be played normally depending on the type or condition of the USB device.
tip
Aunsoft VRO to AVI Converter - Convert VRO Videos to AVI
Best Way to Deinterlace VRO Videos - Convert VRO to AVI <br /><br />.VRO files are created by DVD video recorders or camcorders with Mini-DVD disc using the DVD-VR format. The disc has a 'VR_MOVIE.VRO' file, containing the raw audio and video data for all video recordings. The recording metadata along with navigation data are stored in the 'VR_MANGR.IFO' file. A backup copy of this file (VR_MANGR.BUP) is presented as well. VRO Codecs: MPEG2, same as VOB but uncompressed raw video and audio. So in some cases you can treat the VRO files just like .VOB files, but in many cases you can not use, play or edit VRO file easily. <br /><br />Audio Video Interleave (AVI) is a means of digitally storing audio and video media content in a file for playback. AVI-formatted files employ the file extension .avi. The header portion of the AVI-formatted file provides details about the file contents, such as width, height, and frame rate, while the chunks of information store the actual audio and video data. A key advantage of AVI format is its ability to be played on the majority of computers worldwide. <br /><br />With Aunsoft <b><a href="http://www.aunsoft.com/video-converter/">Best VRO File Converter</a></b>, we can convert VRO file to AVI with best quality, fastest converting speed, excellent A/V sync and so on. And we also can use the VRO File Converter to convert VRO file to friendly video formats just like mpg, wmv, mkv, mp4, mov, mpeg, dv, etc for playing on iPad, iPod, iPhone 4, iTunes, QuickTime, PSP, Apple TV, Android Phones, etc so that we can watch our favorite VRO conversion file everywhere. <br /><br />Follow the step to <b>convert VRO files to AVI</b> now. <br /><br />Step 1: Free download, install and launch <b><a href="http://download.aunsoft.com/video_converter/videoconverter_setup.exe">best VRO to AVI Converter</a></b>. <br /><br />Step 2: Click "Add" to browse the documents for the VRO videos you want to convert from DVD Recorder or Mini-DVD Disc. You can add more than one file at a time. <br /><br />Step 3: In the drop down list menu of "Format", please select the output video format you want to get. You want to convert VRO videos to AVI, just select AVI. Then specify a location on your computer where the new file should be saved. <br /> <br />Tip: If you want to trim or crop your VRO files and get the wanted part or area, if you want to replace original audio and add background music to the VRO videos, if you want to deinterlace, remove interlaces or image noises of the videos, please click "Edit" to get into editor windows and start your DIY process. <br /><br />Step 5: Click "Convert" to begin converting the VRO to AVI files. Quickly you could get your converted files with high quality. <br /><br />Now wish you have already known how to convert VRO files from DVD Recorders or Mini-DVD Discs to AVI. Don't hesitate, download and <b><a href="http://www.aunsoft.com/best_vro_to_avi_converter_-_convert_vro_files_to_avi/">convert VRO to AVI</a></b> now.
tip
Audio files/MP3 and ring tones
Discovery: You are able to download wave files (and other audio file types) to your phone and even be given the feature, 'set as ring tone' -DONT.
You will find that your phone malfunctions if you set anything other than an MP3 from your phone's MP3 folder, as a ring tone.
It's the fault of the phone's firmware that leads you to believe you can select a ring tone from an audio file that is stored outside of the MP3 folder.
 It is also evident, with the limited memory the phone itself has to store MP3s, that you will NOT be able to personalize ring tones for every contact in your phone book!  Again, this is not explained in the manual properly and has led to much confusion surrounding MP3 functionality on the Prada LG.
I hope this helps.
3answers
DOES NOT PLAY AUDIO ON MKV FILES.IS THERE A NEW FIRMWARE?
Because it isn't an industry standard, not all media players support it yet, even though support is rapidly growing. There are two main options for playing MKV files. These include, using an MKV compatible media player or downloading the appropriate codecs.
See more details and suggestions at
2answers
I can not play movies in my totem movie player, AMR is missing
Hi..
AMR (Adaptive Multi Rate) is common audio file format for mobile devices like mobile phones, laptops, portable recorders.. etc.
in fact totem movie player can't play any amr files (files encoded in amr codec) by itself. Totem Player depends on Gstreamer libs, which haves necessary media handling components .
from your post its not clear that whether your totem can't play movie files from the very beginning or just you can not play movies recently.
your totem player may lacks Gstreamer library files or somehow your Gstreamer libs got corrupted recently.
Reinstalling Gstreamer Library file may help you.
you can find latest source version of Gstreamer on this page
(more detailed download of Gstreamer can be found on http://openports.se/multimedia/gstreamer-0.10 )
How do i set my music as ring tones after they were transfered to the htc i touch diamond verizon phone
  1. Save the Audio file to your device or MiniSD memory card
  2. Use the File Explorer to browse to the stored mp3 file
  3. Tap and hold the audio file until the sub-menu appears
  4. Select "Set as Ring tone"
1helpful
Marantz cdr420 recorded media stored on harddrive.played back all fine unplugged now it says no valid files when i try to burn the disc but the drive reads full.
If you are attempting to burn mp3 files as an audio CD, then that's the problem. You cannot burn audio CDs from MP3 files. You have to burn MP3 files as a data CD and not as an audio CD. See excerpt taken from page 33 in the CDR420 user guide. "Prepares CDs that can be played on standard CD players. Compact Disc Digital Audio (CDDA) uses uncompressed PCM, .wav files. The CDR420 does not convert MP3 files to PCM so MP3 files are ignored if you choose AUDIO as the CD TYPE"
No audio devices installed cant play audio files
First check if a windows machine by going to start/control panel/sound and audio devices and see if a sound card is listed. Check the setting under hardware and audio. You need two essentials to play audio files. You need a sound card and the software to play audio files. Most desktop computers come with some type of sound card but you can buy one from a local "Best Buys", "Walmart" online or computer store. They are relatively inexpensive and can be installed as a DIY in an open PCI slot inside the back of your machine or take it to a computer store. Windows Media Player comes with Windows and Apple's Quick time with Macs so that should take care of the player end of things. Hope this helps out. Give me some feedback if it does. Thanks
2answers
.OGM , .MKV file
MKV and OGM are two container formats - Matroska and Ogg Media respectively. That is, they are computer files that contain various types of multimedia data, in particular video, audio and subtitle tracks. A container might contain one video track and multiple audio and subtitle tracks of a variety of languages. They can also contain chapter-information, and meta-data (tags). Quicktime MOV and AVI are other examples of container files.
  • If you want to watch these videos on your computer, then you don't need MKVtools or any other video converter. Just download either VLC Media Player or MplayerOSX . Both applications can play MKV and OGM files.
Thanks
Iqbal
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
