Question about Tomtom XXL 540S GPS Receiver
My new Tom Tom will not start past the first screen that shows the name Tom Tom.....how do I get it to operate properly. If I depress the start button for about 14 seconds it goes to a green screen or shuts off.
  • Tomtom Master
  • 514 Answers
It is likely that your battery is low or nearly-dead, particularly if you haven't used your GPS for a while and it has not been plugged in (to be kept charged). That's why it doesn't start (even if it is plugged in when you're trying to start it up again now). Don't try to repeat the startup (too often) as it will mess up your sw / data (when your battery is low or half dead) You'll want to plug it in (e.g. using your USB or wall adapter) for up to 24 hours or so, to charge the battery. Then start it up and keep it plugged in until your battery is fully charged.
Posted on Feb 13, 2011
  • lee house Jan 30, 2012
    tried charging for 24 hours but still no luck. any other ideas?
SOURCE:
My tom tom one when i swith on the screen shows the sd card being removed from tom tom with a red cross across sd card.the sd card is in side .i can not past this screen or use gps how do i fix thanks
It is likely that the SD card (data) is corrupted. I'm assuming that it had previously worked properly.
Have you tried running a (fix) disk utility against your (internal disk or SD card) storage for the GPS ?
For instance, connect the GPS to your PC (Windows), and select (highlight) the (internal) "disk" on the GPS device. Under File - Properties, go to the Tools (tab) and run the "Error-Checking" option.
This utility may fix your data error.
If not, consider doing a restore (from backup) of your GPS disk storage.
Mar 24, 2013 | Tomtom One XL GPS Receiver
Our Tom Tom was working well until we shut it down. Now we cannot get past the introductory page and when we press continue it flickers but does not progress any further
Do not panic when your devices start to malfunction, it is just a minor problem that can be fixed easily. The reason it does not get pass the introductory page is because a file that supports its operation is missing.
What you have to do is to reset your device using a computer. Data transfer might not work properly if the connection to your computer is through a USB hub or keyboard.
  1. Reset your navigation device by holding the power button for about 15 seconds, then it restarts itself.
  2. Connect your navigation device to your computer, then switch on your device.
  3. Tom tom home starts, is the page you first get.
  4. If home offers new application, click 'back',
  5. Delete the tom tom application from your device and computer by clicking 'manage my navigation device',
  6. Reinstall the application by clicking 'update my device',
  7. Safely disconnect your device.
If the device still does not get passed the introductory page then you need to try backing up and restoring your device.
That should do the job.
Dec 23, 2010 | Tomtom One XL GPS Receiver
Screen stuck on tom tom with red hands
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Sep 21, 2009 | Tomtom GO 300 GPS Receiver
Tried to update my Tom Tom One by connecting to my
Remove the SD card
Update your device without the SD card.
Make sure your GPS runs OK without the SD card
Now re-connect the tomtom but don't let tomtom home run. exit TTH if need be.
then just copy ALL the files from the tom tom to your sd card
Once all the files are on switch off the tom tom and insert the sd card and re-boot
It should now work again
Sep 14, 2009 | Tomtom ONE GPS Receiver
When turned on, screen has picture of unit with blinking "x" in lower right side and what looks like a "disc" in lower left. will not respond.
Remove the SD card
It should now work
Sep 11, 2009 | Tomtom Go 700 Portable GPS Receiver
Large white X in red circle flashing
This works for most tomtoms so there is nothing to loose and everything to gain
Remove the SD card
formatting is better done in a card reader.(opionions vary)
It should now work
Aug 27, 2009 | Tomtom GO 930 GPS Receiver
Tom Tom Go 730
trying to find how to got pin tom tom go 730
Jun 27, 2009 | Tomtom GO 910
My tom tom one XL turns on but doesnt go past the start up screen
If you are talking about the Main Menu that shows only 5 icons, tap change preferences, then show all menu options. From there you will see all the icons and menus that are available for your One. Thanks for using Fixya!
Jan 26, 2009 | Tomtom ONE GPS Receiver
TomTom frozen
uninstall and then reinstall the app again:
www.tomtom.com/9091
Jun 29, 2008 | Tomtom ONE GPS Receiver
Tomtom XXL 540S GPS Receiver Logo
703 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
