The retraction mechanizm is likely jammed. Mostly likely the cord has jumped it's groove in the retraction wheel/hub. If you are good with tools there is a 70% chance you can get it to work again with a basic DCR operation. Most mechanical problems can be solved using this simple rule: Dissassemble Clean and Reassemble.
CAUTION: The retract mech has a powerful spring inside, avoid exposing. Most retract mech units are rivoted closed so consumers won't poke thier eye out.
CAUTION: UNPLUG THE UNIT
Open the unit from the bottom and the top lid of the canister should come off.
The retract mech should be obvious as it is where the cord comes into the unit.
Look for the cord being bound by iteslf either on top or underneath (lie two cordes in one groove)
Remove any binding.
If you see no debris or obsticals for the cord to retract (where it is getting stuck)
Your spring could have sprung!
Do you feel and retract at all?
Can you locate the releae mechagnism?
Does the Release button seem to function? When Pressed it should take pressure off of the cord hub.
The retract mech may need replaced. Overall the cost will be about $60 for parts.
SOURCE: i need the owners manual for kenmore cannister 24212
If you type in the model number on your searchbar, the website will be listed "after" all the sponored sites. Use the site that has YOUR manufacturers name in the url. Under the "support" section choose manuals and especially the term pdf. Thank you, Dana
