Anonymous Posted on Feb 12, 2011
Printer is offline - Office Equipment & Supplies
Level 3:
  • Office Equip... Master 6,688 Answers
  • Posted on Feb 12, 2011
Cindy  Wells
Level 3:
Answers
6688
Questions
0
Helped
3532768
Points
21745
What type of printer are you having a problem with? Is it on and do you see any error messages on the printer? How is it connected to the computer? Do you have the driver installed? Some printers need to have the driver installed with a USB connection before moving to a network install. (For all-in-ones, the driver/software must be installed before you connect the data cable.)
If a wired connection, try new cables (fully seated) and different ports. If it is a USB connection, try a direct connection if the printer is connected to a USB hub or print server. Make sure that the cord is 6' or shorter. Check if other devices work. (I've seen a few computers loose their USB ports for no apparent reason. On desktops, try rebooting the computer and uninstalling the USB drivers and rebooting again. This is in the Device Manager for Windows machines. On a few laptops, sometimes removing the battery and the power adapter will reset the ports.)
For network connections, make sure that your network is up and that you aren't getting signal loss issues (for wireless networks). Try a wired connection to check for network loss. To check a network, I tend to check a few points with the ping command. For Windows, launch the Command prompt and ping the numerical IP location of your router. Then ping the IP location of the DNS server. Can you see the printer on your list of network places. (The format for ping is
ping 192.168.1.1 or ping www.google.com followed by enter. The returned message will be either the time for a small packet of data to go to the location and return or a connection timed out.)
If you are losing your network connection, reboot your router and broadband modem. (Try rebooting the router first.) Make sure your firewall is not blocking access to the printer.
I hope this helps. Please write back for more information with specifics for your printer.
2answers
How can I fix HP Printer Offline Windows 10?
This video shows you how to fix a printer that is offline:
2answers
Can a windshield be replaced on a 1998 dakota without removing the wiper arms
Whats hard about removing wiper arms easy job.Windscreen fitting harder if you get it wrong.
11helpful
6answers
Epson printer offline
In this section, we provide some practical ways to resolve the Epson Printer Offline Issue. Simply follow the mentioned teachings carefully and fix this error on your own.
If your Epson printer is displaying an offline message, it means that there is some connectivity problem between the Epson printer and PC. ... Incorrect printer settings where your printer is not set as "Default Printer" may make your printer go offline. An outdated printer driver may stop your printer from functioning.
In the same way, How do I put my Epson printer back online?
Verify The Printer Connection
Update Epson Printer Driver
Check Printing Status
Restart The Print Spooler Service
Add A Second Printer
Hopefully, now you can surely Resolve this issue. I Hope, this content is valuable for you to solve the Epson printer says offline windows 10.
Epson Printer Not Connecting to WiFi
Epson Printer is Not Responding
2answers
Brother lc1100hy printer offline can't get it to go online
As you've noticed, the Brother printer goes offline with a single update to Windows 10. Even so, Windows 10 updates or driver upgrade is not the only cause for your printer to be offline. The key reason behind a brother printer that displays an offline message in windows 10 is the connectivity issue.
Reasons that cause Brother Printer Offline:-
1.As cable disconnection could also be a reason for the Brother printer offline issue.
2.Faulty USB connections can arise printer offline
Step to fix Brother Printer Offline Windows 10
1.Verify the Brother Printer turned ON and there are no errors on screen.
2. Make sure the Brother printer is connected to the computer properly.
3. Make sure your Brother Printer is set as the default printer in Windows 10 settings.
4. Delete all print jobs from the printer properties option.
Expert Advice - Brother Printer Offline Windows 10
4answers
"The printer is offline. Check that
Issues or errors within the operating system might also cause printer offline issue. Users having offline printer issue are advised to clean the registry of the system, check integrity of the system files and also remove any malware infections using an updated antivirus program. Users must also stop the printer service active on the system and restart it as the issue might be because of errors. Removing the errors from the system would get the printer working without issues.
k24674
ADMIN Andrew
ADMIN Andrew
