SOURCE: Apricorn EZ Upgrade II Cloned Drive Won't Boot - Toshiba P15 479
Basically this product does not do what it is advertised to do. You have to do a custom clone (not typical as suggested) and try to get an exact copy the drive you want to copy.
But... If you are upgrading to a larger drive you will now have to do a diskpart as an external drive in order to get the complete upgrade your drive.
SOURCE: Hard Drive Removal
You have to remove the DVD and after that you will see the HDD under metal shield held in place with 4 screws labeled M2.5X6. Screw to remove DVD was also labeled (F6).
If you don't know how to do it, i suggest to get on line the service manual for further info.
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
