The metal button on the top of the tub is used to turn the tub on/off. the metal button you see in the middle of the tub above one of the jets is the low water sensor.
the water has to be above that metal tab, you have to be in the tub and then touch the metal button on the top of the tub to turn it on.
this system uses the electrical current from our bodies to complete the circuitry and turn it all on and off.
Rod Kidman
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
I finally called a plumber. They quickly found the access cover in the laundry room (next to the bathroom with the jet) and found the hidden GFCI electrical receptacle. Once reset the GFC switch, the jet starts. I had to pay $125.00 for their service.
