HTC G1 Logo
Posted on Feb 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the sim network code for my htctouch how can i get it
Ekse
Level 3:
  • HTC Master 13,435 Answers
  • Posted on Feb 12, 2011
Ekse
HTC Master
Level 3:
Answers
13435
Questions
82
Helped
3984764
Points
38023
Call your service provider
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
1helpful
Sim
Did you mean your Samsung S8000 Jet phone displaying invalid Sim card?You need to unlock it from current network lock,to use other network sim card.Visit the site Mobileunlocksolutions.com get unlock code and unlock it easily.Then use with any GSM network sim card.Check whether unlock code is available for your network and country.If it is available get it and unlock it.You can unlock only GSM network locked phone.You cannot unlock CDMA network locked phone.After unlock your phone you can use any GSM network sim card in it.You cannot use any CDMA network sim card in it.
14helpful
4answers
1helpful
Sim card not supported
If the Sim card Not support means it may locked to network.You need to unlock it...You can get the network unlock code from the site Onlinegsmunlock.com/samsung/rs7wp8/ for SAMSUNG GSM Network locked Phones and unlock it from Network lock.You need to specify the Model?
ALSO check whether it not support only one Sim card,if that problem means it may CDMA Network,OR may Sim card problem.If it not support other Sim card and support only one Sim means it's Under Network lock,You need to find the network,country it locked now and unlock it using the Unlock code,Only GSM Network lock Phones can be unlocked,CDMA network locked Phones cannot be Unlocked from the Mobile Phone.
2helpful
2answers
How can i unlock "SIM
To get the Sim Network Unlock Pin You can reach here Prounlocking and get the code and Unlock it from Network Lock...
Imei 351574040156423 Need "SIM network unlock
You Can Get Sim network Unlock Code from this vendor : Sim Network Unlock Code
Invalid SIM
If your Phone says Invalid Sim while inserting the Sim Card means It locked to some Network,you need to Unlock the Phone from the Network Lock,To use any GSM network Sim card in the Phone,You need to find in which Country's Network it locked now? then what is Model,Brand ? specify those details and get The IMEI unlock code,i means Network Unlock code from here Mobileunlocksolutions and Unlock it,Using the Unlock instructions You can unlock the phone step by step also correctly without error....You can use any GSM Network Sim card in the Phone after Unlock it,You cannot use any CDMA network Sim card in the Phone after Unlock it...
17helpful
5answers
How do i unlock a sim card with a puk code?
contact the service Provider........
1helpful
Nokia N70
I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery.
I also need to know the make and model of phone, the network that the phone is locked on, and the country the network is from. Then I will give you the codes. If this is what you want.
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Special Code/Service Provider Lock Code:
This code is required to allow a phone locked to a particular network's SIM cards to be used with a SIM card from another network. The unlock code varies from individual Handset to Handset, and Network to Network.
Which is the one that you want?
Top HTC Computers & Internet Experts
Paul Carew
john h
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
