Solution 1:
Just do following with your phone:
Windows key > Settings > System > Clear phone memory
This will hard reset your phone
Solution 2:
There is a boot menu that allows you to do the hard reset (or reset to factory defaults) without using Phone Reset utility.
1. Remove the battery
2. Reinsert the battery, be ready to press two keys on the keyboard
3. Once backlight goes on, within 1 second press and hold win-key (top left) and O.
4. In the menu press W to select clean boot
5. Press Win-key to boot the phone.
My x ray is restarting on its own ... plz help .... ??
SOURCE: How do I reset my
To perform a hard reset:
Or you may also do the following below.
1. hold volume down key + power key
2. phone will turn into boothrom mode (screen is like rainbow)
3. hold 2 metal buttons (left and right front buttons) and press with stylus on the back RESET button for couple of seconds
4. After while press R on keyboard to perform reset
5. enjoy
SOURCE: need to reset sony ericsson xperia 10x cell phone
The Sony Ericsson Xperia X10 is highly customizable and you have been hard at work tweaking it to your liking, but now the fun is over and you want to return it to its factory settings again.
Here, we show you how to hard reset the Sony Ericsson Xperia X10 with step by step instructions.
Please note that all data will be deleted from the Sony Ericsson Xperia X10 as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
1. From the main home screen, tap menu
2. Tap Settings, then SD card & phone storage
3. Tap Factory data reset
4. Tap Reset phone
5. Enter your password, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
1. Turn the power off. If your Sony Ericsson Xperia X10 is frozen, pull the battery out and reinsert it
2. Hold the Left and right buttons located beneath the display
3. Press and release the Power button
4. Follow the on-screen instructions to hard reset your Xperia X10
All data including third-party applications will be deleted from the Sony Ericsson Xperia X10. Once the wipe is complete, the phone will reboot to its factory fresh state.
Regards.
1ST IS :
1-Turn off your Sony Ericsson Xperia
2-Remove the battry and replace it back in
3-Press anda hold down the left and right silver buttons just under the screen
4-With the stylus,press in the hole on the right side of tehe battery
5-After 10 seconds,you will be prompted to press the R key on your silide-ou keyboard
6-If successful press the Space Key on your slide-out keyboard to finalise changes
2nd IS :1 From the Xperia 10 Home screen, tap the applications bar.
2 Tap Settings > SD card & phone storage > Factory data reset > Reset phone.
3 Enter your screen unlock pattern.
4 Tap Erase everything.
Done! Now, You can reset your Xperia X10 to its factory default settings.
This is a soft rest its never hardrest, pls we someone to give haedrest solution,-even when there is password, which can be removed easiy
