The laserjet 3015 has a weird issue with the logic board. The paper jam is caused by some sensor issues with the logic board. Some issues may not be fixable. The 2009 series of this printer should be under warranty from HP to get a proper board. On the converse, you could try thicker paper; and set your paper thickness on the printer. If you can open the top cover and then close it; it will reset the sensor.
Printed pages are VERY light, and the fuser temperature is low. The toner is not fixed on paper. Still it don`t give any errors. A detailed diagram of the power souce have anyone?
The firmware is corrupted, formatter (mainboard) on the printer is damaged, there is nothing you can do to fix it. Take it to an authorized repair center
The problem is the locking arms on the right side of the machine are probably broken. HP has a tech bulletin out on this issue and they have a kit with updated parts to repair it. It is a very common problem.
