None,this water cycle is controlled exclusively by the "mother-board/main-board in the lower rear area of the unit,the only other possibility would be is if the water solenoid valve isn't completely shutting off and letting water enter after a timed fill per the motherboards circuit timer or you are using the wrong ice cube tray(s) that may be of too small capacity,the boards new number is WR55X10942 made by G.E.Corp
Hi, if your water is overfilling then you probably need a faceplate for your icemaker. If you remove the cover on your icemaker(pry on the corners and pull at same time) You will see a screw with a spring on it. That adjust the water flow. If you tighten you decrease the water. Make sure the gears are not corrioded. If it is. Replace the plate with the gears on it.
Upon looking it appears that the only thing in the front of the ice maker is the electric motor
I assume you are talking about the icemaker motor which is working to make cubes properly. The problem is that there is too much water loaded into the tray
I took out the icemaker to look for a n arm
