I purchased a Jensen VM9424 double din indash Nav unit used and will install this weekend. I am worried that I will need an "unlock code" once I power the unit. Does anyone know the unlock code and procedure for this unit? Thanks in advance
From what I have read, the code will be six digits? Do you enter the code with the remote or on the touchscreen?From what I have read, the code will be six digits? Do you enter the code with the remote or on the touchscreen?
you have to turn off the gps time there is a setting in the menu that you turn off navigation sync or something like that. Go to setup and nav time. It is whatever setting has to do with navigation time
Which NAV system are you using with it? KNA-G510, etc needs to be plugged into the NAV port on back and then you need to go into the System Settings to enable the NAV option and voice interruptions correctly. You'll want to look for AV Interface in the System Settings.
