SOURCE: Fisher & Paykel smart drive
It is either the inlet valve or the pump. If the pump is fine you need to replace the inlet valve. Here you can find parts.
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
