Honda 6370C - Parallel Power Kit For  EU3000i Logo
Posted on Feb 11, 2011
Honda generator eu2000i will only run choked. I had the carb cleaned, plug cleaned, replaced the fuel and I cleaned the spark arrestor. It purrs with the choke open and the ecco throttle works when it is choked. When it is not choked it is starving for fuel runs very rough and the ecco throttle does not work. Also while it is running with choke under load and I try to turn the choke off it shuts down. Thanks for any help, Mike
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4944
Points
Clean the carb again and blow all passages with air. make sure the harness to the carb is all the way plugged in.
My Honda eu2000i shuts down after 30 seconds and have to restart 4 times before it will continue to run normally, does it mostly in the cold Canada winters
it is not any kind of car or truck,so moved you to portable elect gas generators.
does it burn gas/petrol or LPG?
with engine stalled, oil lamp on is 100% normal
but never at the time of stall (or just before)
the oil pump runs off the crankshaft is why.
new spark plug is cure. i bet.
or use chock longer.
carb, gasoline , petrol.
if spark tip is in raw fuel , turn off chock and crank it dry.
the gen has many buttons switches make sure all are set correct for sure on./off .
is it elect starter or hand cord cranked or both?
2answers
I have a deep eu2000i inverter, the problem is to remove the carburetor throttle, it takes some kind of setting as to start the engine low speed, and connect a tool fails ....
if your question is that my Honda generator wont idle up when I connect a load (tool) and it stalls then . first see if unit will run on constant setting (switch on front) if nothing or still barely runs or stalls , then your problem is carb or fuel filter (inside tank) one or both is most likely dirty and needs replaced/cleaned
Honda generator
The running on choke is caused by a fuel restriction. Check the fuel flow from the tank to the carburetor.Change the fuel filter if it has one. If its good, then the restriction is in the carburetor. The generator is shutting down due to the low rpm coming from the engine. A carburetor rebuild may need to be done.
2helpful
2answers
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
1helpful
2answers
Eu2000i lopes while idling. If i slide the choke
Also not uncommon to see a plugged idle circuit, cant remember how difficult it was to get to, but it's the smallest orifice in the carb, plugs the easiest, and these are real touchy on fuel, keep it fresh!
1helpful
Mcculloch start with choke will run when choke in will not run when use throttle wont pick up
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Yard machine ym26ss straight shaft trimmer. New gas,
1) spark plug
Chain Saws:
Remove Carburetor
Top Honda Electrical Supplies Experts
vince
Paul Carew
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
