Read on this link how to remove the BIOS password: http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
SOURCE: reset bios password
Most laptops do not have one and clearing the cmos will not help.
Contact HP, they have a master password that can get you in. You may have to fax them proof of ownership to get them to help. I had to do this on a laptop.
Hope this helps
SOURCE: delete bios password laptop nc6120
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In
this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS
password. The location of this jumper varies depending upon the motherboard brand. You should
read your motherboard manual to check its location. If you don't have the manual then look for
the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR
CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining
the center pin to either left or right pin. What you need to do, is remove the jumper and join
the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove
it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper
and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or
forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access
to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
SOURCE: bios password for HP compaq tc4400 laptop
Don't try anything. Simply contact the HP tech. support team. They will help u come out of the trouble.
