Blank copies down the centre of the page
posted by chris1547 on Jul 23, 2008
i have a copy centre c20 and i am getting a blank copy down the center of the page this error only occurs when the machine has been on for a few hours (4 - %5). turn the machine off for about 15 to 20 min the problem goes away and then comes back after a few hours. i thought of the corona wire but if it is the wire would the problem be constant.
Comment posted on Jul 23, 2008
i know this is a bad response but i don't see the corona wire i know on other copiers it was a matter of sliding it out and cleaning it but on this copier it just has the drum cartridge and the tone cartridge. it looks more like a laser printer than a copier.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
jaiku
Rank:Wiz Wiz
Rating: 81%, 29 votes
pls check the drum charge grid and toner cardritge. may be the toner is empty or charge and transfer corona wire getin dust.
Comment posted on Jul 24, 2008
pls check the copy cycling when u get a blank copy that time u chek the drum catridge. if image appears in the drum its not a drum and toner problem.its a only transfer corono problem.
if image not present in this drum pls u check the ros unit. and u clean all corono wire end blockes.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on blank copies down the centre of the page:
I don't want to Accept this solution
Can you Help with these Copiers problems?
Copiers
We have 'Smart Ring' on the telephone line with the fax....
Copiers
I pulled a piece of paper out of the delivery while it was...
Copiers
new 3235i went down on a print job. Indicated that paper...
Copiers
Message always shows: Scanner failure. Turn power off then...
Xerox CopyCentre C20 Black and White Copier
La maquina tranco con un papel se removio pero ahora sale...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Top Repair Providers for
Copiers & Faxes
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
X
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
