SOURCE: Netgear WG602 wireless router, Connection Local only !
What I think is you unplgged them at the wrong times.
Do this:
(in this order)
Now tell me the errors, like if it says connection limited,etc...
Thanks,
Cam
SOURCE: laptop cant connect wirelessly
Hey Charlie, If you re-installed your operating system you will need to get the wireless modem driver from your dell disk. For some reason they have not included the drivers in the windows software. If you can't find it then you can go on to the Dell site(obviously on another computer) and enter your service tag and get your drivers that way.
I hope this helps
SOURCE: 2wire 1800hg random no internet/random access, repair/wait fixes
It seems that you said your computer gets the ip address from your router,, which means thru DHCP of the router but if you look at the DHCP settings of your wireless card inside your computer ---the DHCP is OFF -- check your ipconfig/all command as shown in your problem too,,, your wless card does not accept the new IP which comes from your router --as DHCP is OFF on your wless card and sticks with the old ip address whereas the router maintains a new ip for your computer in its table and a mismatch occurs and you loose the internet connection ,,,,thats why repair works and then again the IP changes in the router for your computer and your computer's wless card lags behind and use the old ip adress ..... DHCP--- IS DYNAMIC , WHICH MEANS IT RENEWS THE IP address after some time and you computer gets stuck to the old one ,,, hence mismatch. "you make the DHCP -ON on your wless card too. it will be fine."
SOURCE: wireless internet connection problem
Sound like you might benefit from ugrading your wireless drivers.
http://www.atheros.cz/download.php?atheros=AR5007&system=3
SOURCE: Router connecting to Linksys USB adapter
to confirm if your Network adapter's assigned IP, subnet, Gateway & DNS
Problem solved, read online that Atheros has issues with some Netgear routers so I exchanged Atheros module with an Intel one I had from an old laptop, internet worked immediately!
