Question about Whirlpool AD35USS Dehumidifier
Whirlpool gold dehumidifier, fan is running, but not collecting water. It's in a bathroom, and the temp doesn't get below 60. filter was very dirty and the inside as well, from not cleaning the filter. Have since cleaned filter and inside of unit, and still not collecting water. I've already opened the unit and will do so again, but it would be better served if someone could direct me to a certain spot to start investigating. This this unit is like an airconditioner, isn't it? Is there a way to reset the compressor?
  • Whirlpool Master
  • 43,501 Answers
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Mar 30, 2011
SOURCE:
The unit still makes a running noise but seems to collect no water. this unit is about 4 years old but stopped collecting water about 2 years after purchase
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Aug 30, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
New Whirlpool gold dehumidifier last summer. Used since then. It still runs (fan) but no water is being taken from the air. I clean the filters, looked at coils, they are like brand new. I hate to give up,...
Kim, it may simply be a case of the humidity extraction level being set to HIGH. Lower it to 35%. If it's an analog unit (No LED Display) turn the humidity extraction knob to Maximum. More often than not, this will solve the problem. If it doesn't the humidity sensor may need to be replaced.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Motor runs, but dehumidifier does not collect water
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. The fan running, may be the automatic defrost cycle, that defrost the coils, if they become frosted over. The defrost cycle, depending on the unit and how is was designed, can last any where from 15 minutes up to 45 minutes.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filter on a regular basis, not is the time to do so. And while your at it, clean the cooling coils too.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 30 to 40 minutes and check the water collection bucket. If there's water in it, it's working as it should.
Hope this helped you to solve the problem. Please let me know.
May 03, 2011 | Whirlpool Dehumidifiers
Compressor sounds as if its on, the fan is on, but water is not extrated from the air
If the room air is less than the set air then there is no water in the bucket because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water.
In addition, check to see if the air filter is dirty and/or blocked. Also, the room temperature might be too low, (below 15.5 C/ 60F) and finally, check to make sure that there is no obstruction to the unit, that might be causing poor airflow circulation.
I hope this helps you to troubleshoot and solve the problem.
Apr 28, 2011 | DeLonghi DE500P Dehumidifier
My Goldstar dehumidifier model DH304 runs,but fails to pick up any water
If the room air is less than the set air, then there is no water in the bucket, because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water.
Other things that can cause problems: 1.Check to see if the air filter is dirty and/or blocked. 2. The room temperature might be too low, (below 60 degrees Fahrenheit ) 3. Check to make sure that there is no obstruction to the unit that might be causing poor airflow circulation.
Hope this helps you to troubleshoot & solve the problem.
Apr 28, 2011 | Goldstar DH304 Dehumidifier
I have a whirlpool dehumidifier 70 pint and the fan runs but no longer collection of water...we have had it about 4 years.
heatman101
Oct 04, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a Whirlpool Gold dehumidifier that's about 5 years old. The motor sounds and runs just fine, but it's no longer collecting water. Is it fixable?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 02, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
My whirlpool dehumidifier fan runs, but no water is being taken out of the air; cleaned the filter and still no change; dehumidifier was purchased in August 2008.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 15, 2010 | Whirlpool Dehumidifiers
My dehumidifier fan run .the conpresser clicks on , clicks off
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
May 08, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Whirlpool AD35USS Dehumidifier Logo
8,656 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Perry Mellott
Perry Mellott
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
