How to Clean the Oven Look here! I hope some of these will be helpful for you!
SOURCE: oven won't shut off
Tes, sounds like the relays on the board welded shut or the selector is bad. Looks like the clock and selector are all one unit. If you post a complete model number I can give you a part number and you can look it up on the net to get a price. Catriver..post back.
SOURCE: self cleaning hotpoint stove
Sometimes in self clean it can burn out the element. Need to check the element with an ohm meter and see if it shows resistance. If it shows open then the element is bad. If it shows resistance then the element is ok. Next see if you are getting 220 volts to the element when in bake mode. If you are not getting 220 volts then the control is bad.
SOURCE: Hotpoint self-cleaning oven
I believe they make an oven cleaner for self clean ovens. Don't try regular oven cleaner. Ruins finish.
SOURCE: Oven takes a long time to preheat
Before we go into diagnosis mode, call the customer service # in the owners manual and complain about the problem. They usually will make a concession when it is this close to the warranty period. Let me know what you find out.
