I hoep my air filer need to be changed, I woke up this morning no air, we removed the air filer out on Saturday and forgot to replace. Will replacing give me air, the unit has been in home which was built 5 yrs ago
Clean the Air Filter: If the E1 error code appeared as a reminder to clean the air filter, turn off the unit, and then open the front panel and remove the filter. Clean it with soap and water and let it dry before replacing it. If you can't remove all the dirt and grease it has collected, it's time to replace it.
Two things could be the issue. One is your compressor needs to be replaced or the switch on the left side of the trunk hidden by a panel is off and you need to turn it back on.
The air filter, should actually be under the rider's seat. Key latch to remove the seat should be on the left side just below the seat and when you turn the key it will pop it up. Lift the seat out of the way and you should see the air filter right next to the battery. Hope this works out for you okay!
Transmission shift position indicator light. First check the fuse. If that's the problem it's easier to fix. If not you will have to remove the center console to get to the bulb. You will need a short phillip screwdriver. There always some hard to get to screws under the dash. Look around the edge of the plastic console for screws. If it has a cup holder, look inside it also. Make it a Saturday morning project. DO NOT touch any other electronics you see. The control actuator for the air bag may be there.
Make it a Saturday morning project. Test it before replacing the console cover.
