up grading to a usb machine just makes things easier to down load than with a floppy if you are happy using the floppies then stay with it and save your self money
Sorry, an external floppy drive will not work for a Designer 1. You would have no where to plug the cable in to. The internal floppy drive is quite expensive. You might want to look around for a used Designer 1. You can probably find one for $400-$500. Replacing the floppy drive on yours would cost you almost $400 depending on the local dealer pricing.
Check with some long time Husqvarna Dealers and see if anyone has upgraded any Designer 1's from floppy drive to USB. I have kept all of the used drives that I removed from upgraded machines and I sell them as used at a reduced price.New drives are available to authorized repair centers. They will cost quite a bit.You can also have your machine updated to USB.My recommendation is to find a used drive.
You can have replacement discs ordered from Husqvarna Viking. Visit an authorized Husqvarna Viking dealer for them to order the replacement discs. However, you might luck out and they have some already on hand from a scrapped machine or a trade-in. You can find your nearest dealer by visiting the Husqvarna Viking website - http://www.husqvarnaviking.com and clicking on dealer link down the left side of the page.
You can get the floppy drive replaced. I did tons of them! I don't think it is you. Sometimes you can "wiggle" the floppy a bit with the little flap door open and get it to read. Not a huge deal to replace.
It is just one design of a menu full of designs, is that right? Try re-loading the design from your software and maybe a re-format of the floppy before writing to disk.
Hi, I am just about to buy a designer 1 second hand......I gather that you can have it changed to USB by your dealer,for a couple of hundred pounds however I have also been told to be aware that this will not increase the speed that it reads, apparently they just change the hardware to take a usb stick, the reading software in the machine remains the same. The advantage is that you can download to USB as most computers don't have a floppy drive any more but if you try and put too many designs on your USB the machine apparently will take forever to find them. Hope this is useful.
First you need the USB upgrade kit that has the connectors and parts to change the cover of the machine. Next, you will need a new main circuit board if your machine was made prior to about 2006. At this point, the cost of parts is about $489. If you can get someone to install these for $10, you can get this done for under $500. Otherwise, go to an authorized Husqvarna Viking dealer and check into trading your Designer 1 in for a Designer SE. You will then be able to plug in an external 3.5 floppy drive to read your old disks, a USB stick, or plug directly into your computer and read them from the hard drive (an upgraded Designer 1 can read ONLY from the stick). Used Designer SE's are very reasonably priced since the introduction of the Designer Diamond as the new top of the line and you may be able to get a full manufacturers warranty on the gently used machine.
I am pretty sure you can download Disk 100 free from the Husqvarna Viking website. This has all the embroideries that came free with the machine, plus the alphabets (I think!). You can download this direct to your PC or to a set of floppies, depending on what your Designer needs and what support software you have (or have not) got. If you have no Husqvarna software at all, your PC will not be able to read the floppy. It is in .shv format which PCs are unable to read, being an embroidery machine language only. If you are trying to open the faulty disk in your Disk Manager software, I always found it worked better if I didn't put the disk in the floppy drive of the computer until after I had already opened Disk Manager. Hope some of the above is useful to you.
