2002 Kia Rio Logo
Anonymous Posted on Feb 10, 2011
I purchased a 2002 Kia Rios station wagon and when I press the button for the front windshield sprayer and It then sprays the rear window and when I press the rear window button it sprays the front. How do I reverse this so it works correctly?
  • 1 more comment
  • Anonymous Feb 11, 2011
    How do I reverse it? Like wheres it located, and what do I need to do it? Thank you
    Alrighty. Uhm, how do I switch them. Like what does it look like, what all I need for it? What tools do I need
  • Anonymous Feb 13, 2011
    It's above the headlights..
richochet
Level 3:
Genius:
  • Kia Master 1,026 Answers
  • Posted on Feb 10, 2011
richochet
Kia Master
Level 3:
Genius:
Answers
1026
Questions
Helped
294509
Points
2697
Two tubes coming from washer bottle one to rear and one windshield just reverse tubes
  • richochet Feb 11, 2011
    only two tubes coming from washer bottle locate washer bottle
    switch tubes they will be easy to remove if bottle not in an awkward place
2answers
Volvo c70 windshield sprayer not working
Try disconnecting the tubes from the spray head (under the hood). The press spray button, if nothing comes out, you have a bad pump. It liquid is pumped, then you need to clean or replace the spray heads - they are clogged or damaged
2answers
Rear window washer won't squirt
could be a clog in the line, or blockage at the spray tip, if its on a seperate switch from the front washers check to see if the pump is engaging while the button is pressed, if all washers are activated on same button it is probly the line or nossle tip.
Neither front nor rear windshield washer fluids are spraying.
Hey Barry, go to your local O'Reilly's, Autozone, or Advance Auto and tell them your issue and ask them for their recommendations..... they WILL help you and it will be much easier than listening and trying to understand what I (or anyone) says on here..
1helpful
3answers
Windshield washer fluid does not spray on my. Windshield
Sounds like the spray nozzle is bent or partially plugged up.
2helpful
2answers
Rear windshield wiper sprayer doesn't work but the fronts work fine 2002 jeep liberty limited
The rear wiper has its own pump motor. pull the hose from the wiper and have someone engage to see if there is a clog. do the same at the motor. if bo liquid comes out then its the pump. also check fluid level in reservoir as well as a possible secondary reservoir
2answers
My rear windshield wiper, front and rear windshield washer quit working
Check your fuse:
Junction block location-1999-04 Grand Cherokee
Inside your Jeep.
2answers
My 96 Jeep GC windshield washer isn't squirting. I can hear it run when pushing the washer button and I hear fluid running ; but it doesn't spray on the windshield. Also , my wiper blade in the rear window...
your rear wiper motor might be faulty,in the front i would check your fluid level-if it is full and you hear the pump running-check your washer lines to see if they are pinched-usually around where the hood closes
2answers
Rear windshield washer, no liquid coming out @
check that the jet is not clogged.take a very thin piece of wire,like from a twist tie and clean the hole. maybe the hose is pinched or disconnected.if you spray the rear,you should hear the pump working.i have seen hoses come off and if you spray for 20 seconds,it may leak from the car
2000 Chevrolet Venture front winshield washers won't spray
If it shoots from the pump without lines connected, then there has to be blockage somewhere. You mentioned you blew the lines out, did you blow directly back through nozzles themselves?
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
