SOURCE: toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
thanks,
for your help
SOURCE: flapper will not go down
Troy, the flapper otherwise known as the flush valve is easily replaced. They are also very inexpensive. Sometimes they can become distorted due to the clorine in the water and won't operate in the same way they did when it was new. I bet this will fix your issue and save you money as well.
SOURCE: My saniflo toilet wont flush
You need a new capacator. The motor is trying to run but does not have enough electricty to get the motor up to full speed.
SOURCE: how do i set the flush levels for a glacier bay
http://www.homedepot.com/catalog/pdfimages/f9/f9b2dcf2-bfa0-4622-94d9-7b326c22eb1e.pdf
Go to page 5 & 6 and it will guide you through setting levels.
