Make a system restore point before trying these procedures.
https://social.technet.microsoft.com/Forums/lync/en-US/33cbe041-847d-41b6-a4a5-ff1acee2d460/cant-remove-printer-drivers-in-windows-7-32bit?forum=winserverprint
Would seem to work on 64 bit version of W7 as well.
How to Remove Printer Drivers in Windows 10 8 7 Vista wintips org Windows...
Go to control panel the programs and features to uninstall any thing
you could of course right click on the printer > properties , > compatibility tab > click square and high l
tight your operating system ( win xp , vista , win 7 etc) > apply and ok first
any drivers for the printer should be downloaded from Dell web site and not through the win site list so check all of that first
SOURCE: Scanning problem with A940 AIO Dell printer/scanner
Hi there, just found this solution to work perfectly. i just freaked out for a moment with the same problem. Use this or just type fax and scan in your help function. Hope this helps!
Before you begin, make sure that you've installed your scanner on
the computer and that the scanner is turned on.
SOURCE: can't scan from my Dell AIO 946
OK, I can't believe I'm actually solving anyone's problem, but, this is what solved it for me. Following the instructions in my 946 AIO Owner's Manual, on page 87, there is a heading called Removing and Reinstalling Software. It says if your printer is not working correctly or if communication error messages appear, you can remove and reinstall the printer software. I did just that and my scanner is now back in service!!!! Hope this helps.
SOURCE: Dell AIO 926 driver is not installed, even though I installed it!
Hi, The problem here is that the CD has an older version of
the driver which has some known issues. Few steps will be required to fix this.
XP Driver
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=195205
XP Printer Application
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=205258
Vista Driver
Vista Printer Application
Hope this works... Please rate your feedback!!! Thanks
SOURCE: Dell 810 will not scan
I was able to get it to scan using the camera and scanner wizard through control panel, printer and faxes. On the left chose scanners and cameras in "other places" then when you see the dell printer click it and it will start the wizard. Make a shortcut to it to use again easily. I have given up trying to fix it!
