SOURCE: why I can't boot from DVD
You must have a bootable files in a DVD where system files are usefull as bootup system.
SOURCE: i am unable to instal
Option 1 (HIGLY Recommended): HP servers should come with an install disk that prepares the windows installer for you. Boot from that disk,tell it your OS, and pop in the disk for the OS when prompted. It will come up fine and have all the HP monitoring agents installed.
Option 2: Load the driver the old fashioned way. Unless you have a floppy drive the standard "Press F6 to load drivers" trick won't work. If you do, then you'll need to put the RAID driver on the disk.
Option 3: Use an installation customizer like nLite to pre-add the RAID driver to the Windows 2003 installer.
Good luck.
SOURCE: Hard disk not found message
You need to press F6 and load special drivers for your disk driver card
See which disk adapter your server has and get the drivers on a floppy disk
Put the disk into your computer before seutp, then click F6 when prompted
it will search your floppy drive for them
