SOURCE: Resetting stopwatch dials - Armani AR5331
The 24 hour face on the right of the watch is the time, not the stop watch. The minute timer on the left of the watch face is the minutes for the stopwatch, if this is not resetting to 0 after holding down the lower button on the right hand side of the watch, contact your manufacturer.
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
SOURCE: stop watch will not reset to zero
pull the crown full out reset all hands set time set alarm or second time if you wish and press the crown back.
SOURCE: my tag heuer carrera stop watch doesnt reset
Try this.
Pull the winder out fully. Then press the top right chronograph button to move the centre seconds hand on. Then push the winder back in.
on some models you should only pull the winder half way out.
good luck
SOURCE: I have a tag link automatic CJF2112 and the
Hello
Get this U-Tube link, where all adjustments to your watch has been show. If you need any further assistance, contact the nearest Tag Heuer service center at your town. No user repairable options left with this device.
www.youtube.com/watch?v=alnkRZDHams
OK
