Gaggia brera, coffee beans compartment is full of beans, but when try to make a espresso it grinds the beans, but it then blinks no coffee beans, and ejects some of the ground beans in the used coffee compartment without brewing.
the grounds are dry, it's like theres not enough coffee coming through grinderthe grounds are dry, it's like theres not enough coffee coming through grinder
I got a small pipe cleaner and cleaned the part were the ground coffee should come out of the grinder, it can sort of be reach were u but pre ground coffee, there should be a little foil flap at this covering, when I cleaned it out I found that there was alot of realy hard ground coffee, I think it might have from when it was tested in factory, after I just made sure it was on the finest coarse and made sure was full of beans on top always, hasn't happened since and that was over 2 months ago. Hope this is any help because I couldn't find any on the Internet.I got a small pipe cleaner and cleaned the part were the ground coffee should come out of the grinder, it can sort of be reach were u but pre ground coffee, there should be a little foil flap at this covering, when I cleaned it out I found that there was alot of realy hard ground coffee, I think it might have from when it was tested in factory, after I just made sure it was on the finest coarse and made sure was full of beans on top always, hasn't happened since and that was over 2 months ago. Hope this is any help because I couldn't find any on the Internet.
AnonymousMar 19, 2014
After turning my Gaggia Brera on and after the first step of warming up, all four alarm signals are flashing red and the machine is not functioning. Do you what I have to do? Best Regards PerAfter turning my Gaggia Brera on and after the first step of warming up, all four alarm signals are flashing red and the machine is not functioning. Do you what I have to do?
Best Regards Per
You can't post conmments that contain an email address.
Re: Gaggia brera, coffee beans compartment is full of...
Remove the finger guard from inside the hopper. Problem solved, as long as you don't stick your fingers in the grinder, which would be a different problem :-).
It looks like the Triangle is the problem section, not that I understand why. These machine need servicing every 9 to 12 months if you use them every day.
Are the grounds wet or dry?
Best Regards Per
