Hi you dont mention any error codes if there problems with draining e20 is displayed any blockage in the pump or drain passage can cause this . however you suggest the draining is ok so this is more likley to be a fault in the water level control. an easy fix would be if you found a blockage in the pressure chamber at the base of 2 x 8mm tubes(from pressure switches) located near the sump hose at the bottam of the drum. undissolved detergent is normally the culprit.jw
