Please click on the link below to be able to access the manual of your samsung dvd-vr375 recorder/vcr combot thi
The exact manual for Samsung DVD-VR375 DVD Recorder / VCR Combo is not available but this is the best manual that fits in for your Samsung DVD-VR375 DVD Recorder / VCR Combo
This unit doesn't have a tuner. So unless your TV can provide video out (not a common feature) to the dvd/vcr recorder, you need a tuner. A set-top tuner box for OTA would work. With a little work, you could also use a tuner (USB or PCI slot card) in a computer. Usually you need a converter box unless your video card can output in a non-RGB format. The manual for this device is available here: http://www.samsung.com/us/support/downloads/DVD-VR375 .
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
The DVD-VR375 does not have an HDMI input. The connection should be: • RED WHITE & YELLOW CABLE from your cable box (AV OUT) should connect to the DVD-VR375 (AV IN 1). Set the DVD-VR375 to AV 1 using the INPUT SEL. button. • Next, connect an HDMI cable from the DVD-VR375 (HDMI OUT) to the TV (HDMI IN). Set the TV to the proper source. This connection would allow the recorder to work as a pass through and will let you record TV programs as well as watch your cable channels.
To be able to select AV1, you have to first go into the setup menu and set the control set top box setting to OFF. I think you go to the menu >> setup >> features >> set top box control >> select OFF. Note that this has the side effect of erasing any previously stored timer settings.
