Reason 1: air in the high pressure system
Reason 2: The pump does not work
Reason 3: boiler leakage or other place
Reason 4: The water flow sensor does not work
If you don't have a manual I hope this helps. You can make coffee without "Descale"ing it but it is recommended you don't go too long without doing it. - Make sure that the filled water container is in the appliance. - Turn the program selector to "On" with lighting and place a container under the hot water spout and another under the steam spout. - Press the hot water button, turn the steam selector counterclockwise and dispense hot water until it flows in quiet, continuous streams. - Press the hot water button again. Turn the steam selector clockwise to o, to turn off the water. Regards, Dave - Avalonxls at att dot net
If this doesn't do it for you, you are doing it wrong!
