There are several variables that will determine the gallons used per 24 hour period.
Let's assume that everything is perfect. Your humidifier holds approximately 6 gallons of water, when completely full. The ideal humidity level depending on the outside air temperature is 40 to 50%. Once the humidity level you have it set for is reached, the humidifier shuts off. When the humidity level drops significantly, it turns back on. So, as you can see, it's difficult to come up with an exact figure. But based on if everything was perfect, about 1.5 to 2 quarts per hour or almost 6 gallons in 24 hours.
For more details on this humidifier call 1-800-546-5637.
Hope this helps you.
Rich
