Question about Jabra Stone Bluetooth Headset
Hi iam trying to connect my jabra stone but my cell phone it asking the passkey
    New Friend:
The manual notes that if asked for a pass-key you should use 0000. Give that a try. Hope this helps!
Posted on Feb 16, 2011
SOURCE:
I am pretty sure that the numeric passkey for Jabra BT2070 is 0000 but it doesnot work in my blackberry 8900. how do i connect it to my phone ?
Try this... 1. Turn off the Jabra bluetooth. 2. Turn on by pressing Volume up + power button until the power light comes on steady. 3. Then turn bluetooth from your blackberry 8900 and make the bluetooth seen/available by other devices. 4. Search bluetooth in range...Look for Jabra BT2070 click then will ask you to put the code which is "0000" or "1234". 5. Then check if the steady light comes to blink...
Mar 19, 2011 | Cell Phones
I have lost my cell phone. I have a new cell phone. How do I disconnect my jabra stone 2 bluetooth from the lost phone and connect it to the new one?
hi jorene_crock,
You are in luck!
you do not have to worry about your old phone being disconnected from your headset! just connect the head set from your new phone like you did with you old phone :)
I hope this helps, good luck!
Mar 17, 2011 | Jabra BT125 Headset
How to connect my sp5050 habra to my cell phone
1.Make sure the Speakerphone is off .
2 .Press and hold the answer/end button for approx 7 seconds until the connection status indicator light starts blink continuously .
3 . Set your Bluetooth phone to discover your Speaker phone. 4. Your phone will find the Jabra SP5050 .Your phone then asks if you want to pair with it . accept by pressing 'yes' or 'ok' on the phone and confirm with the passkey or Pin = 0000 (4 zeros) . your phone will confirm when pairing is complete.
Thank You
Dec 09, 2010 | Cell Phones
I purchased the Jabra BT2035 Bluetooth Headset from a long time.... The first time I tried to connect, it connected easily with the passkey or passcode - 0000. One time, I accidentally deleted the...
you need to intorduce again the jabra blutooth to your device. deleting jabra from the list make it forget the connection.
set your jabra to find mode by pressing the poer button for more than 5 seconds wait to blink, and find it using your device. it will again ask for a passcode and it will connect afterward.
Nov 10, 2010 | Jabra BT2050 Bluetooth Headset
Pairing problem
Before you use your Jabra BT130, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 23, 2007 | Radio Communications
Jabra Stone Bluetooth Headset Logo
147 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
