Posted on May 20, 2017
Hello I have a Braun Paximat Multimag 5025 AFE. It worked flawlessly until yesterday when, after switching it on, the LED on the side, instead of the usual green, lighted in red and all the controls on the remote are inoperative. Also, the dimmer for controlling the brightness of the lamp, is off. The lamp lights always at maxim power. Mechanically all is correct. I'm able to operate the projector by push/pulling the arm slide. The fan is spinning too. It seems an electronic problem ?. Artur
5 Related Answers
Jim Auburn
  • 412 Answers
  • Posted on Feb 28, 2011
SOURCE: I require a bulb for a Braun Paximat slide
Try checking with www.bulbman.com They have an amazing assortment of lamps for projectors!
Anonymous
  • Posted on Aug 09, 2011
SOURCE: h i I am looking
Hi guys - did you ever find the manual? Specifically, do you know how the remote is supposed to work?
Anonymous
  • 48 Answers
  • Posted on Sep 15, 2011
SOURCE: Braun Paximat Multimag 250 AF Hand
If you are in the USA send it to Braun service at:
HP Marketing Corp. PO Box 715 16 Chapin Rd. Unit 908 Pine Brook, NJ 07058 800-735-4373
Otherwise check the factory web site for Braun service in your area. www.braunphototechnik.com
Anonymous
  • 48 Answers
SOURCE: I also need a Braun
What is the description of the lamp? Braun's current catalog numbers for lamps are 80231 for the 150W 24V and 80232 for the 250W 24V. If you need a different lamp you should bring the old lamp to a camera store and let them look it up from the bulb manufacturers.
Anonymous
  • 48 Answers
SOURCE: I need bulb for braun
You should take the old lamp to a camera store and see if they can find a substitute.
Where can I get Braun MULTIMAG SlideScan 4000 repaired?
this is from the Braun site in Nuernberg, Deutschland:
HP Marketing Corp.
Tel.: 001-973-80 89 010
P.O. Box 715
Fax: 001-973-80 89 004
Pine Brook, N.J.07058
Email: [email protected]
Braun Paximat Multimag 250 AF Hand operated slide change works but has resistance. When using the remote control the side can only be part viewed and needs assistance by hand operating. I believe there...
I also need a Braun Paximat Lamp bulb 58.8394AMX
Hello, I recently acquired a 'Braun Paximat N 12' all seems to work ok but no slide tray. Any idea where I can get one?
Gepe Universal 50 Straight tray should work. It might even use the Braun CS Compact trays but the Gepe are more common.
2answers
My Braun 3650 is scanning everything RED, I changed computers and is still scanning red, any idea why it's doing that?
See previous fix for black lines problem is likely the same i.e fractures in the flexible cable between the scanning head and mother board, changing this cable will likely cure this fault.
6helpful
Mac can't find the driver for the Multimag 4000 - using cyberview
Hi
lets start with what mac system you have there? the device is supported on Mac: OS X 10.1.5 or higher
Top Braun Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Braun Office Equipment and Supply Expert? Answer questions, earn points and help others
