Hi sandimacewe,
This means that you have a purge unit error. That's the cleaning station on the right where the printhead parks.The error you are getting is telling you that the purge unit is not giving the correct timing signal as it rotates inside 360 degrees. Therefore, something is either broken or jammed inside. If you had a paper jam and tried to forcefully pull it out, you could have pulled the internal gears out of alignment.
You will need to do some maneuvers to try to release the cartridge from its parking position. Please do not force anything. Just take it to a shop if it's hard to move.
Hope this helps.
Thank you for using FixYa.
