Press the 'OK' button, then it'll prompt you to 'Save All Data To PC'. If you have dictation on the portable that you want to save, connect it to the PC and hit 'OK'. It'll go into 'PC Operation Mode' and you can transfer your dictation like you normally would. Then when you disconnect and reboot the portable, you should get the error again.
To clear the error, press 'OK' again, but on the 'Save All Data To PC' screen, instead of pressing 'OK', press 'Esc' (I think that's the other option - this is from memory!) and it'll prompt you to delete the data. Press 'OK' and it'll format the memory and reboot - then you should be good to go.
