Solution:
1. Boot into Linux.
2. Use "fdisk" command to delete "ext" partitions. // In fact, no need to use other tools (e.g. killdisk)
3. Run "fdisk" command as root.
4. For those who don't know how to use "fdisk", I provide an example here. (Read the man page of "fdisk" will be better)
//Remember !!! fdisk can format your hard disk (which will erase all your data), use it with great care -- unless you know what you are doing, otherwise don't use it. (I will not take any responsibility of my suggestion)
i) fdisk /dev/sda
.) For those who use PATA (Parallel IDE) : fdisk /dev/hda
.) For those who use second hard disk : fdisk /dev/sdb (2nd SATA hard disk), fdisk /dev/hdb (2nd PATA hard disk), fdisk /dev/sdc (3rd SATA hard disk) and so on ... {sd [a, b, c, d, ...]}
.) fdisk "what" depends on where your linux partition is.
ii) use "m" to read the available options
iii) press "d"
iv) press the number of the partition you want to delete
v) Remember ! if you don't want to make the change, press "q" at any time. (that means quit without saving)
vi) If you want to make the change, press "w" (that means write the change to hard disk)
5. There may sometimes cause a warning message say something about not synchronize the disk (because you cannot make changes while you are using the partition -- if you are booting the partition now), the change will occur after you shutdown and reboot the system.
6. Okay, you can reboot the system now and you will find that the partition is empty now.
7. You can install XP or what ever now.
** For those who cannot use "fdisk", my simplest suggestion is to re-install Linux if you don't have any other tools (such as killdisk). And then you should be able to use "fdisk". In fedora 8, you can even choose formatting the hard disk in "vfat" file system (which can be recognized by almost all computer include windows xp and so on -- see "File Allocation Table" wiki) during installation. Therefore, no need to run fdisk
SOURCE: Sata Hard Drive not detected on Bios
I would tend to agree that if the ports are set to autodetect it would suggest that they are looking for drives, but go through every item in your bios just to make sure that there isn't some obscure spot where the port is turned off.
If your bios is not detecting a drive your o/s is not going to find it either, and Linux will likely have the driver it needs when you go to load it. What's more, if it doesn't, you're rather hosed until it does.
If everything looks right after checking and rechecking and sleeping on it and checking again, but your bios still won't find the drive, take the drive back and get it replaced.
SOURCE: Hitachi Desk star 500GB SATA drive
HOW MANY PARTITION DID YOU MAKE? HOW MANY GB EACH OF ONE.?
MAYBE YOU DID NOT FORMAT THE OTHERS.JUST REVIEW YOUR PARTITION GOT TO PARTIONING ARE THEN REVIEW IT....... YOU FIND THERE THE PROBLEM,, THAT IS HAPPER TO ME BEFORE...BEST OF MY EXPERIENCE....
SOURCE: sata HDD very slow
Dear friend you need a sata board to get maximum speed of sata driver connect it directly to motherboard sata jack converter does not give full sata speed
SOURCE: External hard drive device installer error
Has it got its own power supply or is it using a two USB ended cable. It could be your laptop cannot supply enough power via one USB port so that it really needs a two ended cable so that two USB ports will power it up. Try this Mark
i hav hitachi hdd it has pass word and i have forget them is there any universal pass word i need them
