Question about HP DeskJet 6988 Printer
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
  • 2,574 Answers
Navigate to this page ->here ..the document explains how to print drivers..other software for HP products.
Posted on Feb 09, 2011
  • HP Master
  • 1,679 Answers
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
Key is flashing. Internet blue light is on. - printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Posted on Feb 08, 2011
SOURCE:
How do i change the language bak to English? And how do i print from my macbook laptop onto the printer
TO CHANGE THE LANGUAGE:
From the printer control panel, press the 'Spanner' icon.
Press the right arrow button, and then press OK
Press OK again.
Press the arrow buttons until the language that you want appears on the display, and then press OK.
If you are sure, press the right arrow button, and then press OK to change the language.
To print from your macbook laptop you may have to install additional software onto your laptop from the installation CD. Insert the CD and wait for the 'Welcome' screen to appear. (Note if the 'Welcome' screen does not appear after a minute, then click the CD icon on the desktop). Double click 'Install' and follow the screen instructions.
Some additional notes that may apply to your machine(s):
If the printer is connected to a desktop computer through the rear USB port and you decide to connect a laptop computer to the printer through the Quick Connect laptop port, then the Quick Connect laptop port connection overrides the rear USB port connection. The active print jobs on the desktop computer may be cancelled. Pause or cancel active jobs on the desktop computer before switching between ports.
To summerise:
Pause or cancel active jobs on the desktop computer.
Connect a USB cable to the laptop computer and then to the Quick Connect laptop port on the front of the printer.
Warning-Potential Damage: Do not plug in or remove the USB cable from the Quick Connect laptop port while a memory device is being accessed by the printer.
If you have not yet installed the printer software on your laptop then install it now.
Hope this helps
Jul 14, 2011 | Lexmark X6675 All-In-One InkJet Printer
Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
Dec 23, 2008 | Kyocera Mita FS 1010 Laser Printer
Samsung ML-2510 will not print from MAC OS on Macbook
Hi, sorry to hear you are having problems,
OK, first of all, you can stop worrying about solution #3, this printer is a USB or Parallel, there is no networking on this printer so no possibility of an AppleTalk connection.
You say you have downloaded the latest version of the driver from the Samsung website.
And, the Mac is connected DIRECTLY to the printer via USB.... ( It won't work if it's connected to a PC and then shared.. well it might work but I have not been able to make this kind of connection work...)
Well, if this is the case and you are unable to print while the PC prints fine, I expect that it is over the Parallel port or do you plug and un-plug between the Mac and PC...
It might be that the printer needs to reset after switching between the Mac and the PC, Shut off the Printer, I mean really, shut it down, unplug it for 30 seconds then connect it to the Mac and restart the Mac and start up the printer....
If it still does not work, do you have another Mac you can connect to for testing?
Also, the first test should not be FireFox, open the Text Edit app and type ( TEST ) and just print that...
Give that a whirl..
Dec 22, 2008 | Samsung ML-2510 Laser Printer
Cannot print from Apple MacBook to Canon MX310
First, check your USB printer connection to your Macbook from your Pixma MX310 printer.
If the USB cable is securely seated, make sure you have installed the updated drivers for your version of Mac OS X. Here is the Link:
Canon Pixma MX 310 Drivers for Mac OS X (v10.6/10.5 and earlier).
If you have already updated your printer drivers to the most current Canon Pixma update for your version of Mac OS X, then click on the Apple menu icon, located in the upper left corner of your screen and select System Preferences.
• From System Preferences, select Print & Fax.
• Within the Print tab, make sure you can see your Canon listed in that window.
If you can, proceed to perform a test print on any document you have on your desktop or folder of choice. If this does not help, from within the Print tab, select the Canon and press the "-" Minus button and remove that printer.
• Once it is removed, now click the "+" button
and re-add your printer.
• Once it has been added, attempt to test print again.
This should help get your printer back to printing again.
Regards,
-Mactechtrainer
Dec 02, 2008 | Canon PIXMA MX310 All-In-One Printer
Print Queue is stuck on
This is old, but I will post my solution for anyone else who might be having this problem.
In Mac OS 10.5: Go to System Preferences under the "apple logo" menu. Then select the "Print & Fax" module. Select your printer from the list on the left, and then click the "Open Print Queue…" button. Select the job(s) you want to cancel, and click the Delete button.
In older Mac OS 10: Go to the Utilities folder in your Applications folder, and open the "Printer Setup Utility". Double click your printer in the list. Then it is the same as above: select the job(s) you want to cancel, and click the Delete button.
Nov 30, 2008 | Apple MacBook Pro Laptop Computer with...
I had the same problem and spent some time trolling the Net. But....I found it.
Run installer from CD.
Tthen go to system preferences > print and fax
Delete the ml-2510 by clicking the minus square
Click the add square..
Select the ml-2510 again, and make sure that at the bottom of this window, under the "Print Using:" field, you again select the ml-2510.
Click add.
That's it! You're good to go!
Aug 05, 2008 | Samsung ML-2510 Laser Printer
Can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
Mar 28, 2008 | Canon PIXMA MX310 All-In-One Printer
HP Laserjet 3050 won't print - os X
Power off printer, disconnect all leads such as USB, network, etc and power on again.
Does it power on to the normal state?
Are there any messages on the control panel or light patterns (eg off, on, flashing etc)?
Dec 30, 2007 | HP LaserJet 3050 All-In-One Printer
Printer not receiving jobs
Hi Mark, first of all,You need to check ports on Your PC ,if this printer is networked.Second, try to set sleep or Energy saver mode on printer to highest possible time.To do that,just press "Menu" key on printer control panel and go through menu to find sleep mode.And maybe best solution is to upgrade firmware on your respectable machine.For that, You need :Compact Flash card type 1,Card reader,and firmware.Obtain or download firmware files or informations about that from Kyocera web site or from Kyocera service partner in Your country. Copy unzipped files to CF card(you need to format CF card on printer -Read user manual )Switch off printer.Push card in CF Card Slot in printer.switch on printer and wait till all light flashing on printer control panel.Switch off printer and remove CF card.You can contact me if you have any problems about that machine.BR
Nov 28, 2007 | Office Equipment & Supplies
HP DeskJet 6988 Printer Logo
328 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
