First
perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar
into the bottom of the dishwasher. Keep the temperature at the highest
setting possible and perform a wash cycle.Then start using a dishwasher
most probably that would solve the problem. If this does not solve the
problem then there must be some parts worn out or faulty creating the
problem.
There are many probable causes of failure .
To
clean the dishes the water temperature is essential.It the water is not
hot then the dishes will not be cleaned properly.So check the water
temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes
