IBM ThinkPad R51 Notebook Logo
Posted on Jul 02, 2017
I have an R51 1836-Q6U. When I turn on the laptop I get a series of screens that show scrambled patterns (these are not the test patterns one would normally see during a bios check of an lcd) they are more of an undecipherable checkerboard. I thought it might be the ccfl but now I'm wondering if it's the inverter. I'm not sure of the symptoms that would require a replacement of an inverter or ccfl? Any help would be appreciated. TIA
matasj89
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 6 Answers
  • Posted on Jul 03, 2017
matasj89
Contributor
Level 1:
Welcome Back:
Answers
6
Questions
0
Helped
1209
Points
16
You should try connecting an external monitor. If it shows nothing at all or a scrambled image or it does load to Windows but won't let you change the resolution or the color space, your graphics chip most probably got overheated and de-soldered itself. There is no easy fix. This would involve taking the laptop apart and either heating the GPU (which would end up being a temporary fix) or sending of the motherboard to professionals who specialize in GPU re-soldering.
3 Related Answers
Anonymous
  • 181 Answers
  • Posted on Nov 26, 2007
SOURCE: Blank LCD Screen
Well, sounds like a couple of things if an external monitor works. First, toggle a couple of times between lcd and external just to make sure that it's not set to external only.
If that's no help, look closely at the lcd while the operating system is running. Can you see any image at all? If so (or if not) you have a bad inverter (we have them at the shop for around 25.00). The other possibilities are a bad backlight (which means a new lcd, about 75.00) or it's possible the lcd cable has simply came loose from it's socket.
That's about all it could be on these models if you're getting an external image. I'm using a T30 right now. They tend to have bad memory slots, but great machines.
Good luck
Anonymous
  • 324 Answers
  • Posted on Feb 18, 2008
SOURCE: Hp Pavilion dv2000 LCD Problems
Does sound like an LCD problem, but doesn't sound like an inverter.
You might want to tear it down and check the connectors on both ends of the LCD cable, to make sure that they are fully connected.
Ron-
Anonymous
  • 8909 Answers
  • Posted on Feb 25, 2011
SOURCE: 2 X IBM T41 laptops,
When the invertors fail, it is common to be completely dead not showing a little light.
Maybe they have both failed but I would check the power save settings first.
Hope that helps.
Scrambled laptop screen
Scrambled is a subjective term that is useless in trouble shooting.
Sounds like a virus.
1helpful
HP Compaq nx9020 scrambles the screen on start
"scrambles"? Has the Laptop been cleaned? Fan and vents? Overheating? You may have to open the unit to clean, also replace the CPU and GPU Thermal Paste, if the Graphics Adapter hasen't been damaged by overheating that may help. It may be Done. Try booting to Safe Mode with Networking, that will apply the generic driver. Perhaps the driver is incorrect or corrupt. post results. Drivers for your computer can be found here , select your OS: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=424540&locale=en_us&taskId=135&prodSeriesId=424676&prodTypeId=321957
Dell HP Pavilion screen scrambled
Either your monitor died or your video card/chip died. Test your tower with a different monitor or test your monitor with a different tower.
Toshiba satellite monitor is scrambled, how to fix?
Check to see if the problem is the screen Inverter, or the graphics chipset, or the LCD screen.
Use an external monitor as a test.
If the screen of the external monitor shows a scrambled display you have a problem with the graphics chipset.
If the screen of the external monitor does Not show a scrambled display, you have a problem with the screen Inverter, or the LCD screen.
90 PERCENT of the time the fault is the screen Inverter.
External Monitor;
1) You can use a CRT monitor, (Looks like a small TV), as a VGA monitor,
Or
2) You can use a flat LCD screen monitor that has a VGA cable.
A) Laptop OFF, and monitor OFF, attach the VGA cable from the External monitor, to the VGA port on the Toshiba Satellite A205 series Notebook PC.
This is an example of a VGA cable, and it's connector, and a VGA connector on the laptop,
http://en.wikipedia.org/wiki/VGA_connector
B) Turn the monitor on. If it is a CRT style let it 'warm up'.
Turn the laptop on.
C) The display is supposed to automatically show up on the external monitor.
If it does not, press, and hold down on the Fn key, and also press the F5 key.
Still no?
Holding the Fn key down, tap the F5 key again.
Display good on external monitor? Problem lies with the screen Inverter, or the LCD screen.
Either OR.
Primer:
An LCD screen does not produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
An Inverter (screen Inverter) is used to convert the electricity provided by the laptop, for the LCD screen, and Backlight.
As previously stated, 90 PERCENT of the time the fault is the Inverter.
Laptop open looking at the display assembly, the plastic thin frame in front of the LCD screen, and surrounds the LCD screen, is the Display Bezel. (Resembles a picture frame)
The Display Bezel is removed to access the screen Inverter.
The Inverter is right behind the Display Bezel, and located at the bottom area of the LCD screen.
The Display Assembly has to be removed from the laptop, to remove the Display Bezel.
Toshiba's term for the Display Bezel is Display Mask.
The Toshiba Satellite A205-S5804 Notebook PC is one of the Satellite A205 series of Notebook PC's.
This is a link to a free Service Manual for a the Satellite A205 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Scroll down to the second Satellite heading. The one that begins with Satellite A10.
Scroll across, and click on A200.
After you click on A200 it may take as long as 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
Go to Page 146.
4.10 Display Assembly
Page 151 shows how to remove the Display Mask.
4.11 Display Mask
Page 153 deals with the screen Inverter.
4.12 FL Inverter Board
Takes a really sensitive (Read fairly expensive) multimeter to test an Inverter.
Due to the low price, and ease of replacing, the screen Inverter is replaced to test whether the old one is bad.
Example of a screen Inverter (FL Inverter Board) for a Satellite A205-S5804 Notebook PC,
http://www.batterysupport.com/toshiba-satellite-a205-s5804-inverter-p-216526.html
Compare to the price of a replacement LCD screen,
http://www.laptopscreen.com/English/model/Toshiba/SATELLITE~A205-S5804/
To summarize so far;
1) Display shows good on external monitor. Replace screen Inverter. Still the same problem? Replace the LCD screen.
2) Display on external monitor is scrambled also?
Fault lies with the graphics chipset.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The graphics chipset is a GPU.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
The GPU for a Toshiba Satellite A205-S5804 Notebook PC (Part Number PSAF3U-0NR00V), is an Intel (Mobile) GL960 Express,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_mobile_chipsets
It is soldered directly to the motherboard, therefore it is Integrated Graphics.
{Integrated Graphics is also known as OnBoard graphics.
ON the motherBOARD.
The GPU is soldered to the motherboard.
In comparison if the GPU were soldered to a removable adapter card, it would be a graphics card, and Not integrated graphics }
This means if the graphics chipset is found to be bad, motherboard replacement is the solution.
{ Disassembly guide,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm }
For additional questions please post in a Comment.
Regards,
joecoolvette
Blank screen on Thinkpad Lenovo T61, when I connect a monitor and reboot it shows scramble.. help
Your video card adapter might be damage. Or you have installed a wrong driver for your laptop.
Another cause of the problem is your RAM or memory might be damage. I suggest you buy a new memory to test it.
Thanks. Cheers!
1helpful
Laptop screen scrambled and now won't turn on
maybe overheating graphics card, check the fan is actually turning on, usually you can hear it whirring around.
I have a hp Compaq 6735s...it refuses to start up...when it passes the post screen it does not show...but i tried booting from safe mode it boots normally...i then repair the OS thinking it was gonna stop...
can you access bios screen (hold f10 during startup)? if so go there and test memory modules (run in test) and this also will test hdd. can you see any blinking/lit leds? then give me more info.
Dell Latitude D610 powering on but not reaching BIOS.
I did a check and the D600 series I am pretty sure is not capable of running Windows 7. Re install the original OS or a Linux and go to the Windows 7 RC page and run the compatibility tool.
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
