Dryers Logo
Posted on Feb 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dryer won't start. The timer ticks as though it's working. I have taken the start button to an appliance repair shop and they siad it was good. I replaced the door switch with a new one and it still won't start. I was supprised that the new door switch's wires were color coded backwards. The red and the blue lined up against opposite colors. Any suggestion would be appreciated as my fix-it manual states that the prior two items are about the only problems that occur when the dryer won't start and the power works?
Bruce Denton
Level 2:
Sergeant:
  • Expert 273 Answers
  • Posted on Feb 08, 2011
Bruce Denton
Expert
Level 2:
Sergeant:
Answers
273
Questions
Helped
51237
Points
772
There is a thermal fuse on the back side of dryer. it will let the tmer motor come on, but it will not let the motor start. its shaped like a bullit and is usually white with 2 wire and one screw holding it on.
Dryer doesn't start
Don't know if your dryer has one but it could be the start relay is bad .
Whiripool dryer t mod leq9508 pro
Sounds like the wire going to the motor from the timer is open somewhere or the contacts in the timer is not making a connection. If you have a schematic you could see which wire feeds the motor and see if it has voltage coming out of the timer.
If it has voltage could be a wire or the start switch I see you said start sw works though. Hope this helps if I think of anything else I'll let you know.
Dryer will not start but timer ticking
If the start button is an "ON - OFF" button (meaning, you can turn the dryer off manually instead of resetting timer in order to switch it off), try turning the dryer ON...then switch it back to "OFF".
Hopefully the dryer will continue, and the thermostat will kick in.
Dec 01, 2013 • Dryers
I have the pth5498 and my tv won't turn on. My
Timer is not the problem---the tick ticking sound is the shutdown circuit in the set that has been triggered by a short somewhere likely in the high voltage area or the convergence circuit---shop repair---says Akai but I suspect set was made by Samsung who owned that name at one time.
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 • Dryers
My dryer wont start when I push the start button. You can hear the tick, tick when turn the timer on. Is it the start button or thermal fuse?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 22, 2010 • Dryers
I have a kenmore front load dryer 80 series and it just stopped working. When you push the start button the timer button makes a ticking noise. What is wrong?
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Oct 25, 2010 • Dryers
Have a Whirlpool GEQ9800LW0 and it won't start. When I set the timer and push the start button nothing happens. The timer still makes it's usual clicking sound but the dryer won't start. What needs...
Check power to the inlet valve, if absent let the program move forward and if the motor does not work either it is possible that thetimer though ticking is not contacting.
So go back to check for the wash cycle, when start is pushed, inlet valve on, water comes in, water fills , triggers level sensors,washing starts with motor on.
If there is no voltage on any parts ,the timer contactor is faulty
1helpful
Faulty Start Button?
If the dryer doesn't even start to turn when you press the start button, then you have to look at a couple things; The start button itself, the starting relay or the safety circuit. You mentioned that there's a ticking sound... if this sound goes away when you open the dryer door but comes back again when the door is closed, then the safety circuit is working.
It could be the switch itself or the starting relay (if equipped with one). If you're mechanically capable, consider looking at the relay. See if the contacts are being pulled in when the start switch is pressed (DANGER: HIGH VOLTAGE). If it is, the start switch is OK.
Hope this helps.
Apr 02, 2008 • Dryers
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
