SOURCE: Dishwasher fills w/ water, does not wash, but does drain.
Joel, it's hard to tell whats going on here without the full model number. The number you posted should start with a 665, 363,587 or 464. Here is a couple of things to look for. It sounds like you have a seperate drain pump. Remove the bottom toe panel and hopefully there will be a tech sheet behind it. Check the harness to the motor itself. You want to verify that there is 120V going to it when the wash motor should be running. If you hear the motor humming and kicking out on the overload, then we can assume you have something stuck in the impeller or the motor is bad itself. The tech sheet will give you a diagram for the hot and nuetral. Check the float switch inside the tub, it should move freely up and down. This is a safety device to insure the dishwasher does not overfill. If this is a 665, there will be a start capacitor on the left side of the wash motor. If one of the wires came off the cap, the motor won't run. Regarding the door switches, if you have 120V going to the motor during the wash cycle, you can assume the door switches are o.k. Hope this gets you started in the right direction...Catriver.
SOURCE: Water in bottom
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
If this helps please vote me a fix ya
SOURCE: specks of "sand-like" food on my dishes; water not draining
I bought a replacement filter and that dramatically cut down on the amount of "specs." Now there are only a few in some of the glasses. I also cleaned out the drain underneath the screen, there were peas and corn in there, I just used a shop vac to **** them out. Seems to be much better now, I think a good inside cleaning of the washer will help out too. Hope this helps...
SOURCE: Maytag mdb7100awb dishwasher is leaking from the
take off the bottom panel there are 4 screws you got take they are 1/4 inch screws once the panel is off turn on the dishwasher and see where exactly the leak is coming from
SOURCE: The upper sprayer arm fell off on my Frigidaire FDBB4365FC0.
I just had the same thing happen and fixed it! You might need to remove the upper rack first. In the "Roof" of the dishwasher, you should see what looks like a plastic gear wheel. It will screw off, but you will need to put a little force to get it started. Inside of the gear is a free floating plastic ring with 2 small teeth on one side. Make sure the teeth are facing down through the center hole of the wheel. Hold the ring with one finger, and snap the spray arm back in place. Just screw the assembly back into the washer and all is good... Until it falls out again...
