Necchi 3102 Mechanical Sewing Machine Logo
Posted on Feb 08, 2011
How to thread a necchi 3102. I am just trying to learn. the bobbin is fine. I need to see a diagram
GLFIcom
Level 1:
New Friend:
  • Contributor 48 Answers
  • Posted on Feb 08, 2011
GLFIcom
Contributor
Level 1:
New Friend:
Answers
48
Questions
0
Helped
7340
Points
70
Not your machine number but maybe this is close.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_3537_threading_Diagram.htm
Do you have a demonstration or diagram of how to thread and install bobbin for necchi 537L sewing machine?
Try this web site:
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
May not have your exact machine but one may be similar enough so you can thread your machine properly.
How do I put the bobbin in
try this link for a manual and the information should be in it Necchi 3101 FA 3102 FB Instruction Manual
Necchi 3205 FA: Seized
It may not have seized there may be a very small piece of thread jammed in the raceway area, you need to take the bobbin case and the raceway out to check
Ned a diagram (or detailed instructions) on to thread a Necchi 3205FA & installing the bobbin. Thanks.
try www.sewusa.com there are threading diagrams for some Necchi models. even if yours isnt there the bobbin should be similar.
How do I thread this machine ?
try sewusa.com they have free threading diagrams
How do I remove the bobbin from a Singer 3102? I have the manual and it doesn't tell me. It is not at all obvious from the machine itself. I can't thread the bobbin if I can't remove it.
Ok which is it? A Singer or a Necchi?
If it is a Singer or a machine like the one picture here.... slide the grey metal plate toward you. You'll see the "drop in bobbin" Look for a little lever or button that will lift the bobbin up so you can get it out.
Bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
1helpful
I was given a Necchi 3102 sewing machine
There are a load of threading diagrams HERE, although your model is not listed, one may be similar enough to get you out of trouble.
As to a manual, a google search should give you several options for pdf downloads
5helpful
2answers
How to thread necchi 537L sewing machine
From the reel pin take the thread to the left and over the top thread guide above the takeup lever, make sure the takeup lever is up and and make sure the presser foot is up, take the thread straight down and round the right hand side of the tension unit and back up the left hand side to the takeup lever, thread the takeup lever right to left and take the thread down any guides to the needle, if the bobbin case goes in the front thread the needle front to back, if the bobbin case goes in the side thread the needle left to right.
1helpful
Unable to get bobbin to pick up thread from needle.
Check the thread coming out from the bobbins maybe on reverse side,also check the bobbins tension adjust it there is a small adjusting screw.Check also the needle alignment lastly check the upper tension from the tension regulator knob,tension adjustment is depend on the fabrics that you sew.
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
