LG 30 in Kitchen Series Dual Convection 5.6 cu ft Electric Range - LRE30955ST Kitchen Range Logo
Posted on Feb 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My oven is not going on -- it light up error f-7 comes up
Anonymous
Level 3:
  • LG Master 1,902 Answers
  • Posted on Feb 08, 2011
Anonymous
LG Master
Level 3:
Answers
1902
Questions
0
Helped
533576
Points
5669
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Oven will not come on error message F31 appears
the oven needs two things 1, gas or electricity plus 2, thermocouple.
If gas try lighting manually by removing oven bottom plate of oven when possible. That puts everything out in the open. If it does not open that way go to the bottom broiler opening and light manually.
this will tell you where the problem is.
Electric oven, go to fuse box and shut off supply line them turn back o n. This is easiest fix and resets the stove. On electric stove there may be an interlock that shuts oven off when the door is open.
Hope this gets you started!!!
4answers
F-7 error code on jennaire oven
I think that is a problem with the control assembly.
Try first unplugging power cord for ten minutes , and see if this clears the error message.
Bottom oven does not work tim eflashes and gives 0-.-7
Child lock is activated go to http://www.defy.co.za/images/manuals/OPERATING%20PROCEDURE%20FOR%20DEFY%20GEMINI%20%20OVEN%20%206%20BUTTON%20CLOCK-TIMER.pdf last page.
Apr 12, 2014 • Ovens
What is error 34-7 we have 8 rational oven in over hotel
I m working on a rational oven CMP61. I repaired the Fan Motor PCB but led light this blinking 7times with motor installed on PCB. Without motor installed on PCB led blinks 11times.
What must the problem give some hint or guidance.
Microwave will not heat
If the microwave is 7 years old or less, there are too things that come to mind, defective magnetron, or the inverter board, cost should be considered when going ahead with repairs.
F7 error built-in oven
F7 is a stuck keypad error. Sometimes you can push every pad at random several times each to unstick the keypad.
If that fails the ERC(clock) will have to be replaced.
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
6helpful
2answers
DCS wall oven F7 ERROR
I TRIED SOLUTION FROM SYMAR DATED MAR 14, 08 IT WORKED FOR NOW. I HOPE IT WILL CONTINUE WORK UNTIL SERVICING...COME MORNING.
Top LG Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
