SOURCE: Sony Ericsson cell phone was dropped in water!
let it dry out before u turn it on it might take a few days or a couple weeks
SOURCE: phone lock code sony ericsson w550i
Ok, THIS WILL WORK! It worked on my W580i and it wasn't even supposed
to. FIRST! Download (8.8MB) XS++ From
HERE:http://forums.se-nse.net/index.php?showtopic=16338
SECOND! No install. It just runs.
Make
sure you have ALL drivers for YOUR phone. That should be under the
bettery. Under model... or something like that. HERE!
http://www.nodevice.com/driver/company/Sony_Ericsson.html
Take
your phone, turn it off. Start this program and click on connect.
You'll have 30 seconds to plug your phone into your computer and HOLD C
The entire time! (the delete button or 2). If connected, then click at
the button: GDFS. There will be a phone lock reset to "0000". Click it.
It will take no more than 45 seconds. I promise. Unplug your phone, and
vuala! If your phone won't turn on, try pulling out the battery,
putting it back and trying again. This program is also good for
flashing phones, and putting flash menues on your phone. Also unlocking
it and debranding it. GOOD LUCK!
SOURCE: Sony Ericsson W350i - replacement hinged keypad cover
While this may not be typically, I just talked with Sony Ericsson and they are sending me a new flip cover at no charge. I should receive it within 3-5 business days.
SOURCE: hI , i am using
Your problem might be,
1. with your mobile phone service provider
2. With your friend's mobile
3. With your mobile itself
To sort out problem 1: Use some other network sim card and try it.
To sort out problem 2: Call to some of your other friends and test it
To sort out problem 3: Use headset connected to your mobile and test it by speaking to your friends via headset. If works fine, then there is some problem with your mobile phone speaker. Test the call using loudspeaker as well. Test the call using a bluetooth headset as well ( if one available with you)
So by the above method you can find out where about your problem is and place a service order to your mobile if needed.
I hope this is helpful to you
Thanks
